Detecting decrease (apogee)
Dear arduino users,
I am working on a rocket project where a parachute should be deployed when it has hit apogee.
I have a working script which measures the pressure (BMP180) and converts this to relative height. A kalman filter is used to filter out the noise. My idea was that as soon apogee (maximum height) would have been reached and the height would decrease a parachute can be deployed. This was tried with the following line:
if (estimated_altitude>2 && estimated_altitude--)
{Serial.println("descending");
I tried to see if this would work and walked up the stairs and almost as soon I was above 2 meters it would print 'descending', but I was still walking up the stairs and not down the stairs. Can somebody help me how to create a sort of if current_value < previous_value then deploy parachute?
Some clearification:
estimated_alittude is the height estimated using the Kalman filter and apogee should be based on this number.
This is the code that has been used:
#include <SimpleKalmanFilter.h>
#include <SFE_BMP180.h>
SimpleKalmanFilter pressureKalmanFilter(1, 1, 0.01);
SFE_BMP180 pressure;
// Serial output refresh time
const long SERIAL_REFRESH_TIME = 100;
long refresh_time;
float baseline; // baseline pressure
double getPressure() {
char status;
double T,P;
status = pressure.startTemperature();
if (status != 0) {
delay(status);
status = pressure.getTemperature(T);
if (status != 0) {
status = pressure.startPressure(3);
if (status != 0) {
delay(status);
status = pressure.getPressure(P,T);
if (status != 0) {
return(P);
// BMP180 Pressure sensor start
if (!pressure.begin()) {
Serial.println("BMP180 Pressure Sensor Error!");
while(1); // Pause forever.
baseline = getPressure();
float p = getPressure();
float altitude = pressure.altitude(p,baseline);
float estimated_altitude = pressureKalmanFilter.updateEstimate(altitude);
if (millis() > refresh_time) {
Serial.print(altitude,6);
Serial.print(",");
Serial.print(estimated_altitude,6);
refresh_time=millis()+SERIAL_REFRESH_TIME;
This is wrong. Think again what you want to do.
You want to compare the value to the last time you took a reading.
Exactly, I want to compare the current reading to the last time reading. I am quite new to Arduino. How would you do this?
In the old days we used a mercury switch.
You would have a global variable called perhaps "lastAltitude" and use that to compare it to the current altitude. Then after the comparison update this "lastAltitude" variable to the latest reading.
Note a global variable is one declared outside of any function.
Yes that was before the world got paranoid about mercury.
It was fascinating stuff to handle.
I see what you mean. I can see how this would work if you get 10 readings.
For example altitude[9] < altitude[10], means increasing
altitude [9] > altitude [10], means decreasing and falling.
However, how is this done with 'live' readings?
Sorry for not completely understanding how to do this and being a noob to arduino.
No you don't.
if (estimated_altitude < lastReading) {
lastReading = estimated_altitude;
How is lastReading declared?
So anywhere outside of a function, it is normal for this to be just before the setup function.
float lastReading = 0;
