I'm planning on a project that will be able to detect a net floating underwater. I'm trying to figure out if it's even possible to use sonar to check if a shape is a loose grid, like a floating net would be. Even just to see if it's a big flat thing that isn't an animal or something, and to have it print something when it does. Is this beyond the hardware capabilities of an arduino? could I use four sonar sensors pointing at two slightly different places? It would also all have to work underwater so I don't even know if underwater sonar sensors are a thing for an arduino. Anyway, any help or advice would be much appreciated, I want to figure out if this is even viable.
Please do some research first. Then build a prototype. Then ask.
Your post vanished, but you may ask google for "sonar fishing net detection". The first link leads to West Coast | NOAA Fisheries and by reading that paper you could conclude that it's way above your head. Sorry.
Yes. Underwater sonar devices require specialized, high voltage electronic drivers.
