Determine which com port has Arduino attached
In the IDE and in Visual Micro, it’s able to tell me if the com port is an Arduino DUE USB port or a Programming port.
Is it able to ask the Due this info or is it getting it from a Windows Driver for those ports?
I would like to do the same.
My first thought was that I could open the port with the special baud rate and ask it questions. If it supported that sort of thing.
Some boards with native USB support (like the Arduino Leonardo, Due, Uno R4, or ESP32 S3) can provide a VID (Vendor ID) and PID (Product ID) when connected. I guess the IDE could use these to suggest a matching board profile, but the actual board selection remains mostly a manual process.
one technique is for the host program to transmit a prompt over serial to the target microcontroller which responds with know text, e.g. in the case of a SIM_A7670E modem transmit AT+CGMM which responds with A7670E-LAS
e.g. using C# is call the SerialPort.GetPortNames Method then iterate thru the ports
// C# send prompt to serial ports looking for a apecific response
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Threading.Tasks;
using System.IO.Ports;
using System.Threading;
namespace ListCOMports
    class Program
        static void Main(string[] args)
            // Press Ctrl+F5 (or go to Debug > Start Without Debugging) to run your app.
            Console.WriteLine("COM ports");
            // Get a list of serial port names.
            string[] ports = SerialPort.GetPortNames();
            Console.WriteLine("The following serial ports were found:");
            // prompt each port with ? look for response "ESP32+BME280"
            foreach (string port in ports)
                SerialPort serialPort1 = new SerialPort();
                Console.WriteLine(port);
                try
                    serialPort1.PortName = port;
                    serialPort1.Open();         // attempt to open serial port
                    serialPort1.BaudRate = 115200;
                    Console.WriteLine("serial port open OK {0}", serialPort1.PortName);
                    serialPort1.Write("?");     // prompt with ?
                    Thread.Sleep(100);
                    // check response (if any)
                    String response = serialPort1.ReadExisting();
                    Console.WriteLine("response " + response);
                    if (response.Contains("ESP32+BME280"))
                        Console.WriteLine("ESP32 with BME280 found !!!");
                    serialPort1.Close();                                                        //open OK, close it
                catch (Exception ex)
                { Console.WriteLine("serial port open fail {0} ", serialPort1.PortName, ex); }
ESP32 test program
// ESP32 - on ? prompt respond with "ESP32+BME280"
  delay(2000);
  while (true) {
    char ch = Serial.read();
    if (ch == '?')
      Serial.println("ESP32+BME280");
    if (ch == 'G') break;
  Serial.println("program found");
void loop() {}
when run the C# program console displays
COM ports
COM1
serial port open fail COM1
COM6
serial port open fail COM6
COM18
serial port open OK COM18
response ESP32+BME280
Press any key to continue . . .
