Hello, I have run into an error that im not sure whats causing it. I have went in and wrote serial.println's into a lot of my functions just to see whats happening, not finding much, will post the output as well.
alarm_volume = 100
LED_strip_mode = 0
LED_strip_pin = 25
LED_strip_count = 10
LED_strip_brightness = 2
vibration_mode = 0
vibration_pin = 26
vibration_strength = 512
micro_dot_pHAT = 0
info_line = 1
brightness1 = 50
brightness2 = 100
brightness3 = 10
date_format = 0
time_format = 0
NO invert_display defined = -1
display_rotation = 1
temperature_unit = 1
disable_web_server = 0
NO [wlan0] ssid
NO [wlan0] pass
[wlan1] ssid = EmpireXerxes
[wlan1] pass = Empire001
NO [wlan2] ssid
NO [wlan2] pass
NO [wlan3] ssid
NO [wlan3] pass
NO [wlan4] ssid
NO [wlan4] pass
NO [wlan5] ssid
NO [wlan5] pass
NO [wlan6] ssid
NO [wlan6] pass
NO [wlan7] ssid
NO [wlan7] pass
NO [wlan8] ssid
NO [wlan8] pass
NO [wlan9] ssid
NO [wlan9] pass
No invert_display defined in INI.
Entered playWAV
volumeGain:1.17
Guru Meditation Error: Core 1 panic'ed (LoadProhibited). Exception was unhandled.
Core 1 register dump:
PC : 0x401a6e79 PS : 0x00060530 A0 : 0x800f28ce A1 : 0x3ffb1eb0
A2 : 0x3ffb21f8 A3 : 0x3f4151bc A4 : 0xe0000000 A5 : 0x3ff2b851
A6 : 0x00000002 A7 : 0x00060323 A8 : 0x8000beb2 A9 : 0x3ffb1e90
A10 : 0x00000000 A11 : 0x00000044 A12 : 0xffffff40 A13 : 0x3fdfffed
A14 : 0x00000000 A15 : 0x00000007 SAR : 0x0000001c EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x4008ec91 LEND : 0x4008eca1 LCOUNT : 0xffffffff
ELF file SHA256: 0000000000000000
Backtrace: 0x401a6e79:0x3ffb1eb0 0x400f28cb:0x3ffb1ed0 0x400de1f1:0x3ffb1ef0 0x400e0867:0x3ffb1f20 0x400f8276:0x3ffb1fb0 0x40091c4e:0x3ffb1fd0
Rebooting...
ets Jul 29 2019 12:21:46
rst:0xc (SW_CPU_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
clk_drv:0x00,q_drv:0x00,d_drv:0x00,cs0_drv:0x00,hd_drv:0x00,wp_drv:0x00
mode:DIO, clock div:2
load:0x3fff001
I am GUESSING that maybe it's caused by volumegain 1.17? Maybe it doenst go above 1.0? Not sure what would cause that unless in my float i did something wrong. If so ill post the audio code (float and variable) to see if you guys can help
however if its not a volume gain problem i am totally lost
serial output:
Entered playWAV
volumeGain:1.17
Rebooting...
got ␀M5Core2 initializing...axp: vbus limit off
axp: gpio1 init
axp: gpio2 init
axp: rtc battery charging enabled
axp: esp32 power voltage was set to 3.35v
axp: lcd backlight voltage was set to 2.80v
axp: lcd logic and sdcard voltage preset to 3.3v
axp: vibrator voltage preset to 2v
touch: FT6336 ready (fw id 0x10 rel 1, lib 0x300E)
OK
GOT SD.BIGIN
passed system checks
PACISCREEN GOOD
M5Stack CORE2 code starting
Free Heap: 234748
SD Card Type: SDHC
SD Card Size: 15193 MB
Ini file exists
section 'config' has an entry 'PA_CI_1' with value
section 'config' has an entry 'token' with value
bootpic = null (was a file on sd, took out to test)
[wlan1] pass = **************
Entered playWAV
volumeGain:1.17
Rebooting...
Now im thinking its either volume, or the playwav command (playwav has always worked before, i just added new entries to the case list) OR im complelty out of it and don't know what im saying lol.
Any help would be appreciated.
