Hello! I'm using the library DFRobot_MCP23017.h on NANO ESP32 board and i have trouble in compile.
Below you can see the output:
In file included from C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:2:
c:\Users\STERGIOS\Documents\Arduino\libraries\DFRobot_MCP23017-master/DFRobot_MCP23017.h:127:27: error: expected ')' before '&' token
DFRobot_MCP23017(TwoWire &wire = Wire, uint8_t addr = 0x27);
In file included from C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/Arduino.h:223,
from C:\Users\STERGIOS\AppData\Local\Temp\arduino\sketches\B8181C72A8CE2F11A73E666B827C4C2F\sketch\MCP23017_DfR_Test_1.ino.cpp:1:
C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:47:61: error: 'digitalPinToGPIONumber' is not a type
#define pinMode(pin, mode) pinMode(digitalPinToGPIONumber(pin), mode)
c:\Users\STERGIOS\Documents\Arduino\libraries\DFRobot_MCP23017-master/DFRobot_MCP23017.h:145:7: note: in expansion of macro 'pinMode'
int pinMode(ePin_t pin, uint8_t mode);
C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:46:66: error: 'digitalPinToGPIONumber' is not a type
#define digitalWrite(pin, val) digitalWrite(digitalPinToGPIONumber(pin), val)
c:\Users\STERGIOS\Documents\Arduino\libraries\DFRobot_MCP23017-master/DFRobot_MCP23017.h:154:7: note: in expansion of macro 'digitalWrite'
int digitalWrite(ePin_t pin, uint8_t level);
C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:42:65: error: 'digitalPinToGPIONumber' is not a type
#define digitalRead(pin) digitalRead(digitalPinToGPIONumber(pin))
c:\Users\STERGIOS\Documents\Arduino\libraries\DFRobot_MCP23017-master/DFRobot_MCP23017.h:162:7: note: in expansion of macro 'digitalRead'
int digitalRead(ePin_t pin);
c:\Users\STERGIOS\Documents\Arduino\libraries\DFRobot_MCP23017-master/DFRobot_MCP23017.h:299:3: error: 'TwoWire' does not name a type; did you mean 'TwoWire_h'?
TwoWire *_pWire;
TwoWire_h
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:19:22: error: 'Wire' was not declared in this scope
DFRobot_MCP23017 mcp(Wire, /*addr =*/0x20);//constructor, change the Level of A2, A1, A0 via DIP switch to revise the I2C address within 0x20~0x27.
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:19:22: note: suggested alternative: 'pipe'
pipe
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino: In function 'void setup()':
C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:47:83: error: invalid conversion from 'int8_t' {aka 'signed char'} to 'int (*)(DFRobot_MCP23017::ePin_t)' [-fpermissive]
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:39:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPA0, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:47:61: note: initializing argument 1 of 'int DFRobot_MCP23017::pinMode(int (*)(DFRobot_MCP23017::ePin_t), uint8_t)'
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:40:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPA1, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:41:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPA2, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:42:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPB7, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:43:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPA4, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:44:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPB6, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:45:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPB5, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:46:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPB4, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:47:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPB3, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:48:7: note: in expansion of macro 'pinMode'
mcp.pinMode(/*pin = */mcp.eGPB2, /*mode = */INPUT_PULLUP);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino: In function 'void loop()':
C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:42:87: error: invalid conversion from 'int8_t' {aka 'signed char'} to 'int (*)(DFRobot_MCP23017::ePin_t)' [-fpermissive]
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:69:24: note: in expansion of macro 'digitalRead'
uint8_t value1 = mcp.digitalRead(/*pin = */mcp.eGPB7);
C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\cores\esp32/io_pin_remap.h:42:65: note: initializing argument 1 of 'int DFRobot_MCP23017::digitalRead(int (*)(DFRobot_MCP23017::ePin_t))'
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:70:24: note: in expansion of macro 'digitalRead'
uint8_t value2 = mcp.digitalRead(/*pin = */mcp.eGPB6);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:71:24: note: in expansion of macro 'digitalRead'
uint8_t value3 = mcp.digitalRead(/*pin = */mcp.eGPB5);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:72:24: note: in expansion of macro 'digitalRead'
uint8_t value4 = mcp.digitalRead(/*pin = */mcp.eGPB4);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:73:24: note: in expansion of macro 'digitalRead'
uint8_t value5 = mcp.digitalRead(/*pin = */mcp.eGPB3);
C:\Users\STERGIOS\Desktop\MCP23017_DfR_Test_1\MCP23017_DfR_Test_1.ino:74:24: note: in expansion of macro 'digitalRead'
uint8_t value6 = mcp.digitalRead(/*pin = */mcp.eGPB2);
Multiple libraries were found for "Wire.h"
Used: C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\libraries\Wire
Not used: C:\Users\STERGIOS\Documents\Arduino\libraries\Wire
Using library DFRobot_MCP23017 at version 1.0.0 in folder: C:\Users\STERGIOS\Documents\Arduino\libraries\DFRobot_MCP23017-master
Using library Wire at version 2.0.0 in folder: C:\Users\STERGIOS\AppData\Local\Arduino15\packages\arduino\hardware\esp32\2.0.13\libraries\Wire
exit status 1
Compilation error: 'Wire' was not declared in this scope
Any help would be greatly appreciated
