dh11 decimal formatting (solved)
Hell guys,
i'm running the script from bruh automation, FULL CODE RAW
here is the thing:
i want to change the output of the dh11 temperature and humidity, because they show up like 45.00 and 23.00
so i want to get rid of the tho zeroes.
what i did try was this in the void sendState() section for my mqtt json string :
float t = dht.readTemperature();
root["temperature"] = t ,0 ;
in the monitor it shows up loke this :
"temperature":31,"
there is a comma i can't get rid of it...
when i use this in the void LOOP section it shows up correctly but i can't use it :
if (isnan(t) || isnan(h)) {
Serial.println("Error dht sensor");
t = t - 1.00; //correction
Serial.print("humid: ");
Serial.print(h,0);
Serial.print(" %\t ");
Serial.print("Temperature: ");
Serial.print (t,0);
Serial.println("*C");
it prints like this :
temperature : 23
regards
The simplest solution, then, is to store the temperature and humidity as ints, not floats.
what i did try was
misusing the comma operator.
The comma separates arguments in a function call. When no function is present, the comma does something COMPLETELY different.
PaulS:
Hi Paul,
Can you give me an example how to store as ints?
im not very good at coding, still learning a lot.
thatks for the fast reply
Welcome,
Use round(), and cast to int if needed. Example
float f = 34.56;
int i = (int)round(f);
i = 35
guix:
Welcome,
float f = 34.56;
i = 35
shows up like this
"temperature":31,"
still that comma there...
i did this :
int i = (int)round(t);
root["temperature"] = i;
i found it , i did change it to (String)i; and it works now.
thanks all for the quick reply!!!
That was the worst possible way to address the problem.
You probably should visit the http://snippets-r-us.com forum instead of the Arduino forum, since you are so fond of snippets.
