Hi
I am very new to arduino and am trying to use the DHT11 sensor and library but i keep getting error messages that i cant find a solution for
#include <DHT.h>
#include <DHT_U.h>
#define dht_apin A0;
Serial.print("DHT11 Humidity and Temperature sensor\n\n");
DHT.read11(dht_apin);
Serial.print("Current Humidity");
Serial.print(DHT.humidity);
Serial.print("Current Temperature");
Serial.print(DHT.temperature);
delay(5000);
here is my code, it is probably attached incorrectly but i dont know how to attach it. Everything is probably wrong but it would be great is i could get started learning with some help
And the errors you are seeing are . . ?
Please remember to use code tags when posting code
#define dht_apin A0;Lose the semicolon
Try this,
#include <DHT.h>
//#include <DHT_U.h>
#define dht_pin A0
#define DHTTYPE DHT11
float Temperature;
float Humidity;
DHT dht(dht_pin, DHTTYPE);
Temperature = dht.readTemperature(true); //true = fahrenheit
Humidity = dht.readHumidity();
Serial.print("Current Humidity: ");
Serial.println(Humidity);
Serial.print("Current Temperature: ");
Serial.println(Temperature);
delay(5000);
Thanks
the code is much better than mine however in serial monitor it says temperature and humidity are nan
endermaker:
Thanks
Check your wires, make sure your using the pullup resistor
How do i use pullup resistor?
endermaker:
Have a look at this for reference
Sorry i made a mistake, i forgot a part in setup. try this,
#include <DHT.h>
#define dht_pin A0
float Temperature;
float Humidity;
pinMode(dht_pin , INPUT);
dht.begin();
delay(5000);
endermaker:
Still not working
Hmm im not sure. i use that code for dht22 i have never used a dht11 tho i think it should work. What value resistor are you using can you show your wiring?
Try changing A0 to 14? assuming your using an arduino.
The value of A0 is 14 on the Uno
Changing the 2 float values to integers make them both read as 0
Usually NaN is problem with wires or sensor.. if you change the floats to int you will lose the decimal
What can I do about this?
