DHT22 Library Including Error
Hey guys, I am making a simple project of sensing the temperature using DHT 22 and Arduino UNO and i have been getting this error continuously. I have tried different codes, different libraries but the error persists.
Even Re-installing Arduino IDE didn't help, need some guidance.
Thanks :slight_smile:
Code Used:
// Example testing sketch for various DHT humidity/temperature sensors
// Written by ladyada, public domain
// REQUIRES the following Arduino libraries:
// - DHT Sensor Library: https://github.com/adafruit/DHT-sensor-library
// - Adafruit Unified Sensor Lib: https://github.com/adafruit/Adafruit_Sensor
#include "DHT.h"
#define DHTPIN 2     // Digital pin connected to the DHT sensor
// Feather HUZZAH ESP8266 note: use pins 3, 4, 5, 12, 13 or 14 --
// Pin 15 can work but DHT must be disconnected during program upload.
// Uncomment whatever type you're using!
//#define DHTTYPE DHT11   // DHT 11
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
//#define DHTTYPE DHT21   // DHT 21 (AM2301)
// Connect pin 1 (on the left) of the sensor to +5V
// NOTE: If using a board with 3.3V logic like an Arduino Due connect pin 1
// to 3.3V instead of 5V!
// Connect pin 2 of the sensor to whatever your DHTPIN is
// Connect pin 3 (on the right) of the sensor to GROUND (if your sensor has 3 pins)
// Connect pin 4 (on the right) of the sensor to GROUND and leave the pin 3 EMPTY (if your sensor has 4 pins)
// Connect a 10K resistor from pin 2 (data) to pin 1 (power) of the sensor
// Initialize DHT sensor.
// Note that older versions of this library took an optional third parameter to
// tweak the timings for faster processors.  This parameter is no longer needed
// as the current DHT reading algorithm adjusts itself to work on faster procs.
DHT dht(DHTPIN, DHTTYPE);
  Serial.println(F("DHTxx test!"));
  dht.begin();
  // Wait a few seconds between measurements.
  delay(2000);
  // Reading temperature or humidity takes about 250 milliseconds!
  // Sensor readings may also be up to 2 seconds 'old' (its a very slow sensor)
  float h = dht.readHumidity();
  // Read temperature as Celsius (the default)
  float t = dht.readTemperature();
  // Read temperature as Fahrenheit (isFahrenheit = true)
  float f = dht.readTemperature(true);
  // Check if any reads failed and exit early (to try again).
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  // Compute heat index in Fahrenheit (the default)
  float hif = dht.computeHeatIndex(f, h);
  // Compute heat index in Celsius (isFahreheit = false)
  float hic = dht.computeHeatIndex(t, h, false);
  Serial.print(F("Humidity: "));
  Serial.print(h);
  Serial.print(F("%  Temperature: "));
  Serial.print(t);
  Serial.print(F("°C "));
  Serial.print(f);
  Serial.print(F("°F  Heat index: "));
  Serial.print(hic);
  Serial.print(hif);
  Serial.println(F("°F"));
Error Message
C:\Users\krush\AppData\Local\Temp\.arduinoIDE-unsaved20241029-16568-19i6rbu.60ns\DHTtester\DHTtester.ino:8:10: fatal error: DHT.h: No such file or directory
 #include "DHT.h"
compilation terminated.
exit status 1
Compilation error: DHT.h: No such file or directory
Welcome to the forum
Have you installed the DHT library and, if so, how did you do it ?
Which version of the IDE are you using ?
Libraries Used: DHT Sensor Library and Adafruit Unified Sensor Lib
You may be using them, but did you install them ?
Yes i have installed them through library manager
Please post your full sketch, using code tags when you do
Is the DHT.h file on your PC ?
If so, then please post the full path to it
These are the all the DHT.h files
So this is the tester code from the library i have installed, i also tried different code but the same error keeps repeating itself
#include "DHT.h"
  dht.begin();
  delay(2000);
    return;
  Serial.print(h);
  Serial.print(t);
  Serial.print(f);
  Serial.print(hic);
  Serial.print(hif);
Error Message:
C:\Users\krush\OneDrive\ドキュメント\Arduino\libraries\DHTtester_copy_20241129141013\DHTtester_copy_20241129141013.ino:8:10: fatal error: DHT.h: No such file or directory
exit status 1
The problem is almost certainly the non ASCII characters in the path to the libraries
what should i do now?
Move the sketchbook (and hence the libraries folder) to a path that does not have non ASCII characters in it
You can change the folder name in the IDE preferences and move the contents of the original folder to the new one using the File Explorer in Windows
Thanks BOB, saved my ass :slight_smile:
I am glad that I could help
Good luck with your project going forward
