I've been trying to use the code that allows you to use a serial enabled LCD to show the temperature and humidity percentage from a DHT22 sensor.
When I upload the code and power it on the screen I get random characters with 'Temp and CRH' among them. The actual temperature and humdity don't however show, so I've done something wrong although I can't figure out what.
Here is the code I used and I was hoping someone could let me know where I've gone wrong:
//Libraries
#include <DHT.h>;
#include <SoftwareSerial.h>
// Attach the serial display's RX line to digital pin 2
SoftwareSerial mySerial(3,2); // pin 2 = TX, pin 3 = RX (unused)
//Constants
#define DHTPIN 7 // what pin we're connected to
#define DHTTYPE DHT22 // DHT 22 (AM2302)
DHT dht(DHTPIN, DHTTYPE); //// Initialize DHT sensor for normal 16mhz Arduino
//Variables
int chk;
float hum; //Stores humidity value
float temp; //Stores temperature value
mySerial.begin(9600);
dht.begin();
//Read data and store it to variables hum and temp
hum = dht.readHumidity();
temp= dht.readTemperature();
//Print temp and humidity values to serial monitor
mySerial.write("Humidity: ");
mySerial.write(hum);
mySerial.write(" %, Temp: ");
mySerial.write(temp);
mySerial.write(" Celsius");
delay(2000); //Delay 2 sec.
spycatcher2k:
You bought it, post a link to where you bought it from.
I have to ask why not? do you know the screen that well you don't need it?
Basics :
If you get a new piece of kit, read the manual/Datasheet and understand what you have read.
If there is a library for it, try the examples and read them, again understand what you have read.
If you need an item and not sure what to get, browse the usual sites, get the manuals/Datasheets, read .etc.
Electronics is 80% learning, 10% blowing stuff up and 10% actually making stuff by my reckoning.
I naively assumed that all serial enabled LCDs worked the same but obviously that doesn't make much sense thinking about it. It just didn't occur to me but since it was pointed out I've been reading it and I haven't had much success yet but I'll go over it again to see how I get on.
Geez, it's such a simple process. Open the sketch in the IDE. Use the Edit menu, and select the Select all menu item. Then, use the Edit + Copy menu item to copy the sketch.
Come back here, and use the </> icon on the top row to generate code tags. Paste your code between the tags.
//Libraries
#include <DHT.h>;
//Constants
//Variables
int chk;
dht.begin();
mySerial.write(254);//move cursor to beginning of first line
mySerial.write(128);
mySerial.write(" "); // clear display
mySerial.write(254); // move cursor to beginning of first line
The write() method is for sending binary data. I doubt that the mySerial device you have attached (I thought you said you had an LCD attached) understands how to deal with the binary value of the float.
Naming the instance LCD would be a far better idea. Using the print() method to send floats would be a better idea.
