Hello friends
My problem is that I am using the dhtlib library and I am getting the values with the dht22 sensor I have installed. Until now, everything is in its normal content, I am using ntc to measure the temperature, my problem is that when it reaches 102 degrees, the screen resets and I continue after 100 in the form of 1/2/3. This is only in the dhtlib library. In the other DHT_senso_lib library, it goes up to 125 degrees without any problems. What I want to do is when I change the dhtlib library. I can show the numbers up to 125 degrees without resetting the source code and I'm adding the
how should i change dhtlib folder now
#include <Arduino.h>
#include <U8g2lib.h>
#ifdef U8X8_HAVE_HW_SPI
#include <SPI.h>
#endif
#ifdef U8X8_HAVE_HW_I2C
#include <Wire.h>
#endif
#include <dht.h>
#define DHT22_PIN 8 // DHT22 sensor
dht DHT;
int hum; //Stores humidity value
int temp; //Stores temperature value
U8G2_SSD1306_128X64_NONAME_F_HW_I2C u8g2(U8G2_R0, /* reset=*/ U8X8_PIN_NONE);
void setup(void) {
u8g2.begin();
int chk = DHT.read22(DHT22_PIN);
u8g2.clearBuffer();
u8g2.sendBuffer();
void loop(void) {
u8g2.begin();
//Read data and store it to variables hum and temp
hum = DHT.humidity;
temp= DHT.temperature;
u8g2.clearBuffer(); // clear the internal memory
u8g2.setFont(u8g2_font_logisoso20_tr); // choose a suitable font
u8g2.drawStr(0,10,"Hello World!");
u8g2.setCursor(45, 40);
u8g2.print(temp);// write something to the internal memory
u8g2.sendBuffer(); // transfer internal memory to the display
u8g2.firstPage();
[/code]
dhtlib
// FILE: dht.cpp
// AUTHOR: Rob Tillaart
// VERSION: 0.1.35
// PURPOSE: DHT Temperature & Humidity Sensor library for Arduino, AVR optimized
// URL: https://github.com/RobTillaart/DHTlib
// http://arduino.cc/playground/Main/DHTLib
// HISTORY:
// 0.1.35 2021-12-16 update library.json, license, #pragma once,
// move private defines to .cpp file
// 0.1.34 2021-11-13 fix negative temperature DHT22 again (code from DHTNew)
// 0.1.33 2021-02-16 fix #6 T-GO signal in handshake. (needed for long wires)
// 0.1.32 2021-02-01 fix negative temperature DHT22 again (code from DHTNew)
// 0.1.31 2020-12-15 fix negative temperature DHT22 (code from DHTNew)
// 0.1.30 2020-06-30 own repo;
// 0.1.29 2018-09-02 fix negative temperature DHT12 - issue #111
// 0.1.28 2018-04-03 refactor
// 0.1.27 2018-03-26 added _disableIRQ flag
// 0.1.26 2017-12-12 explicit support for AM23XX series and DHT12
// 0.1.25 2017-09-20 FIX https://github.com/RobTillaart/Arduino/issues/80
// 0.1.24 2017-07-27 FIX https://github.com/RobTillaart/Arduino/issues/33 double -> float
// 0.1.23 2017-07-24 FIX https://github.com/RobTillaart/Arduino/issues/31
// 0.1.22 undo delayMicroseconds() for wakeups larger than 8
// 0.1.21 replace delay with delayMicroseconds() + small fix
// 0.1.20 Reduce footprint by using uint8_t as error codes. (thanks to chaveiro)
// 0.1.19 masking error for DHT11 - FIXED (thanks Richard for noticing)
// 0.1.18 version 1.16/17 broke the DHT11 - FIXED
// 0.1.17 replaced micros() with adaptive loopcount
// removed DHTLIB_INVALID_VALUE
// added DHTLIB_ERROR_CONNECT
// added DHTLIB_ERROR_ACK_L DHTLIB_ERROR_ACK_H
// 0.1.16 masking unused bits (less errors); refactored bits[]
// 0.1.15 reduced # micros calls 2->1 in inner loop.
// 0.1.14 replace digital read with faster (~3x) code => more robust low MHz machines.
// 0.1.13 fix negative temperature
// 0.1.12 support DHT33 and DHT44 initial version
// 0.1.11 renamed DHTLIB_TIMEOUT
// 0.1.10 optimized faster WAKEUP + TIMEOUT
// 0.1.09 optimize size: timeout check + use of mask
// 0.1.08 added formula for timeout based upon clockspeed
// 0.1.07 added support for DHT21
// 0.1.06 minimize footprint (2012-12-27)
// 0.1.05 fixed negative temperature bug (thanks to Roseman)
// 0.1.04 improved readability of code using DHTLIB_OK in code
// 0.1.03 added error values for temp and humidity when read failed
// 0.1.02 added error codes
// 0.1.01 added support for Arduino 1.0, fixed typos (31/12/2011)
// 0.1.00 by Rob Tillaart (01/04/2011)
// inspired by DHT11 library
#include "dht.h"
#define DHTLIB_DHT11_WAKEUP 18
#define DHTLIB_DHT_WAKEUP 1
#define DHTLIB_DHT11_LEADING_ZEROS 1
#define DHTLIB_DHT_LEADING_ZEROS 6
// max timeout is 100 microseconds.
// For a 16 MHz processor 100 microseconds is 1600 clock cycles
// loops using DHTLIB_TIMEOUT use at least 4 clock cycles
// so 100 us takes max 400 loops
// so by dividing F_CPU by 40000 we "fail" as fast as possible
#ifndef F_CPU
#define DHTLIB_TIMEOUT 1000 // should be approx. clock/40000
#else
#define DHTLIB_TIMEOUT (F_CPU/40000)
#endif
// PUBLIC
int8_t dht::read11(uint8_t pin)
// READ VALUES
if (_disableIRQ) noInterrupts();
int8_t result = _readSensor(pin, DHTLIB_DHT11_WAKEUP, DHTLIB_DHT11_LEADING_ZEROS);
if (_disableIRQ) interrupts();
// these bits are always zero, masking them reduces errors.
bits[0] &= 0x7F;
bits[2] &= 0x7F;
// CONVERT AND STORE
humidity = bits[0]; // bits[1] == 0;
temperature = bits[2]; // bits[3] == 0;
// TEST CHECKSUM
uint8_t sum = bits[0] + bits[1] + bits[2] + bits[3];
if (bits[4] != sum)
return DHTLIB_ERROR_CHECKSUM;
return result;
int8_t dht::read12(uint8_t pin)
// READ VALUES
humidity = bits[0] + bits[1] * 0.1;
temperature = bits[2] + (bits[3] & 0x7F) * 0.1;
if (bits[3] & 0x80) // negative temperature
temperature = -temperature;
// TEST CHECKSUM
if (bits[4] != sum)
return result;
int8_t dht::read(uint8_t pin)
// READ VALUES
int8_t result = _readSensor(pin, DHTLIB_DHT_WAKEUP, DHTLIB_DHT_LEADING_ZEROS);
bits[0] &= 0x03;
bits[2] &= 0x83;
humidity = (bits[0] * 256 + bits[1]) * 0.1;
int16_t t = ((bits[2] & 0x7F) * 256 + bits[3]);
if (t == 0)
temperature = 0.0; // prevent -0.0;
temperature = t * 0.1;
if((bits[2] & 0x80) == 0x80 )
// HEXDUMP DEBUG
// CHECKSUM
if (_bits[4] < 0x10) Serial.print(0);
Serial.print(_bits[4], HEX);
Serial.print(" ");
// TEMPERATURE
if (_bits[2] < 0x10) Serial.print(0);
Serial.print(_bits[2], HEX);
if (_bits[3] < 0x10) Serial.print(0);
Serial.print(_bits[3], HEX);
Serial.print(" ");
Serial.print(temperature, 1);
Serial.print(" ");
// HUMIDITY
if (_bits[0] < 0x10) Serial.print(0);
Serial.print(_bits[0], HEX);
if (_bits[1] < 0x10) Serial.print(0);
Serial.print(_bits[1], HEX);
Serial.print(" ");
Serial.print(humidity, 1);
// TEST CHECKSUM
if (bits[4] != sum)
return result;
// PRIVATE
int8_t dht::_readSensor(uint8_t pin, uint8_t wakeupDelay, uint8_t leadingZeroBits)
// INIT BUFFERVAR TO RECEIVE DATA
uint8_t mask = 128;
uint8_t idx = 0;
uint8_t data = 0;
uint8_t state = LOW;
uint8_t pstate = LOW;
uint16_t zeroLoop = DHTLIB_TIMEOUT;
uint16_t delta = 0;
leadingZeroBits = 40 - leadingZeroBits; // reverse counting...
// replace digitalRead() with Direct Port Reads.
// reduces footprint ~100 bytes => portability issue?
// direct port read is about 3x faster
uint8_t bit = digitalPinToBitMask(pin);
uint8_t port = digitalPinToPort(pin);
volatile uint8_t *PIR = portInputRegister(port);
// REQUEST SAMPLE
pinMode(pin, OUTPUT);
digitalWrite(pin, LOW); // T-be
if (wakeupDelay > 8) delay(wakeupDelay);
else delayMicroseconds(wakeupDelay * 1000UL);
digitalWrite(pin, HIGH); // T-go
pinMode(pin, INPUT);
uint16_t loopCount = DHTLIB_TIMEOUT * 2; // 200uSec max
// while(digitalRead(pin) == HIGH)
while ((*PIR & bit) != LOW )
if (--loopCount == 0)
return DHTLIB_ERROR_CONNECT;
// GET ACKNOWLEDGE or TIMEOUT
loopCount = DHTLIB_TIMEOUT;
// while(digitalRead(pin) == LOW)
while ((*PIR & bit) == LOW ) // T-rel
return DHTLIB_ERROR_ACK_L;
while ((*PIR & bit) != LOW ) // T-reh
return DHTLIB_ERROR_ACK_H;
// READ THE OUTPUT - 40 BITS => 5 BYTES
for (uint8_t i = 40; i != 0; )
// WAIT FOR FALLING EDGE
state = (*PIR & bit);
if (state == LOW && pstate != LOW)
if (i > leadingZeroBits) // DHT22 first 6 bits are all zero !! DHT11 only 1
zeroLoop = min(zeroLoop, loopCount);
delta = (DHTLIB_TIMEOUT - zeroLoop)/4;
else if ( loopCount <= (zeroLoop - delta) ) // long -> one
data |= mask;
mask >>= 1;
if (mask == 0) // next byte
mask = 128;
bits[idx] = data;
idx++;
data = 0;
// next bit
--i;
// reset timeout flag
pstate = state;
// Check timeout
return DHTLIB_ERROR_TIMEOUT;
// pinMode(pin, OUTPUT);
// digitalWrite(pin, HIGH);
return DHTLIB_OK;
// -- END OF FILE --
dhtlib.h
#pragma once
// FILE: dht.h
// VERSION: 0.1.35
// PURPOSE: DHT Temperature & Humidity Sensor library for Arduino. AVR optimized
#if ARDUINO < 100
#include <WProgram.h>
#include <pins_arduino.h> // fix for broken pre 1.0 version - TODO TEST
#else
#endif
#define DHT_LIB_VERSION (F("0.1.35"))
#define DHTLIB_OK 0
#define DHTLIB_ERROR_CHECKSUM -1
#define DHTLIB_ERROR_TIMEOUT -2
#define DHTLIB_ERROR_CONNECT -3
#define DHTLIB_ERROR_ACK_L -4
#define DHTLIB_ERROR_ACK_H -5
class dht
public:
dht() { _disableIRQ = false; };
// return values:
// DHTLIB_OK
// DHTLIB_ERROR_CHECKSUM
// DHTLIB_ERROR_TIMEOUT
// DHTLIB_ERROR_CONNECT
// DHTLIB_ERROR_ACK_L
// DHTLIB_ERROR_ACK_H
int8_t read11(uint8_t pin);
int8_t read(uint8_t pin);
int8_t read12(uint8_t pin);
inline int8_t read21(uint8_t pin) { return read(pin); };
inline int8_t read22(uint8_t pin) { return read(pin); };
inline int8_t read33(uint8_t pin) { return read(pin); };
inline int8_t read44(uint8_t pin) { return read(pin); };
inline int8_t read2301(uint8_t pin) { return read(pin); };
inline int8_t read2302(uint8_t pin) { return read(pin); };
inline int8_t read2303(uint8_t pin) { return read(pin); };
inline int8_t read2320(uint8_t pin) { return read(pin); };
inline int8_t read2322(uint8_t pin) { return read(pin); };
bool getDisableIRQ() { return _disableIRQ; };
void setDisableIRQ(bool b ) { _disableIRQ = b; };
float humidity;
float temperature;
private:
uint8_t bits[5]; // buffer to receive data
int8_t _readSensor(uint8_t pin, uint8_t wakeupDelay, uint8_t leadingZeroBits);
bool _disableIRQ;
