Program is supposed to have sevseg at the base of 0, then when the button is pressed display a randomly generated number. Instead it loops until presumably recognized as an infinite loop. I know I need an end case but I'm not sure why what I have isn't working. Any help and optimization is appreciated.
//My Name finished on 10.30.19,
//Sev Seg dice roller
#include "SevSeg.h"
SevSeg sevseg;
int ran = 0;
const int buttonPin = 11;
int buttonState = 0;
void setup(){
byte numDigits = 1;
byte digitPins[] = {};
byte segmentPins[] = {6, 5, 2, 3, 4, 7, 8, 9};
bool resistorsOnSegments = true;
byte hardwareConfig = COMMON_CATHODE;
sevseg.begin(hardwareConfig, numDigits, digitPins, segmentPins, resistorsOnSegments);
sevseg.setBrightness(90);
void loop(){
buttonState = digitalRead(11);
while(buttonState == HIGH) {
ran = random (1,6);
if (ran == 1) {
sevseg.setNumber(ran);
sevseg.refreshDisplay();
if (ran == 2) {
if (ran == 3) {
if (ran == 4) {
if (ran == 5) {
if (ran == 6) {
delay(250);
if (buttonState == LOW) {
sevseg.setNumber(0);
buttonState is not updated in the unnecessary while loop, thats why it hangs. And why do you have all those if's - they serve no purpose..
void loop(){
//Get the state of the button
static byte lastButtonState = 255;
byte buttonState = digitalRead(11);
if (buttonState != lastButtonState) {
lastButtonState = buttonState;
delay(50); //Lazy mans debounce
if (buttonState == HIGH) {
ran = random (1,6);
//delay(250); //Do you really need this delay?
What about replacing this code block:
ran = random (1,6);
if (ran == 1) {
if (ran == 2) {
if (ran == 3) {
if (ran == 4) {
if (ran == 5) {
if (ran == 6) {
delay(250);
with:
void ShowANumber(int num)
sevseg.setNumber(num);
delay(250);
// the original code leading up to the while in loop():
ran = random (1,6);
ShowANumber(ran);
// rest of code
You do need a pinMode() call and probably a debounce, too.
Edit: I forgot to set the random number generator to num instead of ran.
this should work, it's a pretty simple sketch:
#include "SevSeg.h"
SevSeg sevseg;
int ran = 0;
pinMode(buttonPin, INPUT_PULLUP);
byte numDigits = 1;
buttonState = digitalRead(buttonPin);
if (buttonState == LOW) { //LOW because it's an INPUT_PULLUP so it's HIGH by default
ran = random (1, 6);
switch (ran) {
case 1: {
case 2: {
case 3: {
case 4: {
case 5: {
case 6: {
default: {
delay(250);
Obviously, if you are pressing the button continiously, it will print every 250ms the "ran" number.
I don't know if i can/how i should reply but thanks everyone and especially CyberBarby. I don't usually feel right using an answer that goes way beyond what I understand but thankfully I just forgot switch cases existed. Thanks for the answers yall <3
