I have been using IDE 1.0.6 as it worked with a sketch I wrote for an RTC, a DHT and some relays. I now wish to play around with Blynk for the network access. In trying to use their example Servo sketch, I found it wouldn't compile, so I posted my issue to the Blynk forum. A reply suggested that I upgrade my IDE to 1.6.x which lead me to the most recent (1.6.7), but I guess there is now an actual procedure to "install" a library, whereas previously I just needed to get the unzipped folder into the Documents/Arduino/Libraries folder. Following the install instructions given here on arduino.cc to the letter, I am finding that the Manage Libraries will not recognize the Blynk library, regardless of it's name. When trying to manually install the library via Sketch/Include Library/Add .ZIP Libraries, I get the following errors which lead me to believe that this new IDE has completely invalidated every other library that I've accumulated thus far.
Arduino: 1.6.6 (Windows 7), Board: "Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
Specified folder/zip file does not contain a valid library
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\ArduinoCommander-ethernet-master: C:\Users\Jeffy\Documents\Arduino\libraries\ArduinoCommander-ethernet-master
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\aREST-app-example-master: C:\Users\Jeffy\Documents\Arduino\libraries\aREST-app-example-master
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\Blynk: C:\Users\Jeffy\Documents\Arduino\libraries\Blynk
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\CardInfo: C:\Users\Jeffy\Documents\Arduino\libraries\CardInfo
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\ChronodotSet-2: C:\Users\Jeffy\Documents\Arduino\libraries\ChronodotSet-2
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\Chronodot_Set_to_UTC_-05.00: C:\Users\Jeffy\Documents\Arduino\libraries\Chronodot_Set_to_UTC_-05.00
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\DNS_and_DHCP-based_Web_client: C:\Users\Jeffy\Documents\Arduino\libraries\DNS_and_DHCP-based_Web_client
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\DS3231_Sparkfun: C:\Users\Jeffy\Documents\Arduino\libraries\DS3231_Sparkfun
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\Ethernet_Sample: C:\Users\Jeffy\Documents\Arduino\libraries\Ethernet_Sample
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\Phase_1_-_0.1: C:\Users\Jeffy\Documents\Arduino\libraries\Phase_1_-_0.1
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\Phase_1_-_0.2: C:\Users\Jeffy\Documents\Arduino\libraries\Phase_1_-_0.2
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\StandardFirmataEthernet-LED: C:\Users\Jeffy\Documents\Arduino\libraries\StandardFirmataEthernet-LED
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\thingspeak-master: C:\Users\Jeffy\Documents\Arduino\libraries\thingspeak-master
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\Update_RTC_from_NTP: C:\Users\Jeffy\Documents\Arduino\libraries\Update_RTC_from_NTP
Invalid library found in C:\Users\Jeffy\Documents\Arduino\libraries\webServ: C:\Users\Jeffy\Documents\Arduino\libraries\webServ
enabled in File > Preferences.
Can anyone make heads or tales of this matter? TYIA
