What is the difference between char[], char * and char x[] ?
elandh:
Two are valid. One is not.
char x[] declares an array of chars of unknown size. The rest of the statement will define the size and the initial values.
char *p; defines a pointer, but does not make it point to anything. By itself, it is useless. If it is made to point to something, it can be quite useful.
PaulS:
Two are valid. One is not.char x[] declares an array of chars of unknown size. The rest of the statement will define the size and the initial values.
hi PaulS
in arduino we can do char x[] but we should define the size first, and we can't do char[] x it will make error like "expected unqualified-id before '[' token"
char[] x is C# (and maybe other languages).
PaulS:
char x[] declares an array of chars of unknown size. The rest of the statement will define the size and the initial values.char *p; defines a pointer, but does not make it point to anything. By itself, it is useless. If it is made to point to something, it can be quite useful.
If char x[]; is a declaration of an array, char *p; should also be the declaration of a pointer variable and NOT a definition. Definition embeds declaration and not the other way?
GolamMostafa:
How does that help the OP?
...R
