To manipulate text in Arduino, I can use the C language style of string which is an array of characters. Another way is to use the C++ way which is to use the String object.
What is the difference between the 2 approaches? What are the pros and cons of using String object versus an array of char?
For me, it seems like a no-brainer to use String object because the code becomes more readable. Are there situations when using an array of char would be better?
lightaiyee:
The situation when using an array of char and nullterminated strings would be better: if you are programming for a microcontroller which has very limited amounts of RAM available (i.e. 2KB instead of 2MB or 2GB) with no extra "virtual RAM" available in a "swap file".
