I would like to use a differential pressure sensor for detecting airspeed
The selected sensor is MS4525DO
Here is the spec. sheet: MS4525DO
After I run the program, I found that there are some problems in data reading
//#include <WireMW.h>
#include <Wire.h> //I2C library 0x28H
byte fetch_pressure(unsigned int *p_Pressure); //convert value to byte data type
#define TRUE 1
#define FALSE 0
void setup(void)
Wire.begin();
Serial.println(">>>>>>>>>>>>>>>>>>>>>>>>"); // just to be sure things are working
byte _status;
unsigned int P_dat;
unsigned int T_dat;
double PR;
double TR;
double V;
double VV;
while (1)
_status = fetch_pressure(&P_dat, &T_dat);
switch (_status)
case 0: Serial.println("Ok ");
case 1: Serial.println("Busy");
case 2: Serial.println("Slate");
default: Serial.println("Error");
PR = (double)((P_dat-819.15)/(14744.7)) ;
PR = (PR - 0.49060678) ;
PR = abs(PR);
V = ((PR*13789.5144)/1.225);
VV = (sqrt((V)));
TR = (double)((T_dat*0.09770395701));
TR = TR-50;
Serial.print("raw Pressure:");
Serial.println(P_dat);
//Serial.println(P_dat,DEC);
//Serial.println(P_dat,BIN);
Serial.print("pressure psi:");
Serial.println(PR,10);
Serial.print(" ");
Serial.print("raw Temp:");
Serial.println(T_dat);
Serial.print("temp:");
Serial.println(TR);
Serial.print("speed m/s :");
Serial.println(VV,5);
byte fetch_pressure(unsigned int *p_P_dat, unsigned int *p_T_dat)
byte address, Press_H, Press_L, _status;
unsigned int P_dat;
unsigned int T_dat;
address = 0x28;
Wire.beginTransmission(address);
Wire.endTransmission();
delay(100);
Wire.requestFrom((int)address, (int) 4);//Request 4 bytes need 4 bytes are read
Press_H = Wire.read();
Press_L = Wire.read();
byte Temp_H = Wire.read();
byte Temp_L = Wire.read();
_status = (Press_H >> 6) & 0x03;
Press_H = Press_H & 0x3f;
P_dat = (((unsigned int)Press_H) << 8) | Press_L;
*p_P_dat = P_dat;
Temp_L = (Temp_L >> 5);
T_dat = (((unsigned int)Temp_H) << 3) | Temp_L;
*p_T_dat = T_dat;
return (_status);
