I've used this thing before successfully, the program just reads a voltage then outputs it as a SPI master. I was using it to set the gain of a programmable gain amplifier.
Right now if I program the Digispark then the LED starts to flicker showing the program is running, if I reset it (P5) it waits then resumes flickering, but if I plug it into USB it just loops in program mode with the computer reporting USB connect/disconnect cycles and if powered externally the LED never lights and the outputs don't change. It seems like it is losing the program when powered down.
I probably should give up on it but it was really convenient for controlling the amp under test before and all that's really changed is I've tidied up the test jig.
As an update to the above I tried a different board and it remembers its program as expected. I think the first one is damaged somehow.
