Digital Pins are not working
I think i short circuited my digital pins while working on a project. When i set pin 13 as an output i see the light on the arduino board flash but when i hook my led to it pin 13 nothing happens. Is there any hope for my arduino Uno.
are you using digitalWrite(13, HIGH)? because after you define pin13 as output, it still has a state of LOW or rather 0V. and can you describe what the onboard led next to pin13 does (assuming you have a UNO board or similar). and what does "flash" mean? did you upload blink example? what code does it run? are you sure they got short circuited?
...when i hook my led to it pin 13...
Your LED and what size resistor?
Also check that the LED is the correct way around.
If the led on the board is blinking the output pin is working. Unless... there is a broken connection on the board, which is rather unlikely.
I am a newbie and I have exactly same problem. I uploaded the blink program program and the test led on the board works based on the program but my digital output pins are not working. I don't think I have short-circuited the board. Can anyone please provide any help.
Thanks
How do you know they are not working? Are they set to OUTPUT with pinMode?
How are you connecting the LED? This is probably the issue.
Thanks for the reply. Got it working. Wrong resistor was the issue.
