Aim:
To design a circuit that can control (dim/brighten) AC using Arduino. For this purpose, I am using a 6V transformer. The circuit diagram is available here (please ignore the attached circuit diagram).
The program:
* Digital pin that will detect the interrupt via H11AA1.
const int PIN_INTERRUPT = 3;
* Digital pin that leads to MOC 3052 triac driver.
const int PIN_TRIAC = 7;
int dimValue;
pinMode(PIN_INTERRUPT, INPUT);
pinMode(PIN_TRIAC, OUTPUT);
pinMode(LED_BUILTIN, OUTPUT);
digitalWrite(PIN_TRIAC, LOW);
digitalWrite(LED_BUILTIN, LOW);
dimValue = 50;
attachInterrupt(digitalPinToInterrupt(PIN_INTERRUPT), zeroCrossing, FALLING);
* AC frequency = 50 Hz.
* So, time period one full wave = 20 ms.
* Therefore, time period of half the wave (time period from one zero crossing to another) = 10 ms = 10,000 μs.
* Number of steps (taken arbitrarily) = 100.
* => Each step corresponds to 10,000 μs/100 = 100 μs.
* ∴ Time for dimming = (100 * dimValue) μs.
void zeroCrossing(){
int delayMicros = 100 * dimValue;
delayMicroseconds(delayMicros);
digitalWrite(PIN_TRIAC, HIGH);
delayMicroseconds(20);
digitalWrite(LED_BUILTIN, HIGH);
What the circuit is supposed to do:
The external LED connected to AC will glow, and its brightness will depend on dimValue in the code above. Initially, the built-in LED is LOW, but it will glow as soon as interrupts are detected. This will indicate that the Arduino is detecting the interrupts.
The problem:
The inbuilt LED glows, but the external blue LED does not.
What I have already tried:
If I connect the "A" terminal of the MOC3052 to 5V, the LED glows, which means the TRIAC circuit is working fine.
If I read the voltage on "E" terminal of the H11AA1 using Arduino analogRead(), I get a nice graph (attached). The falling lines should be detected by the Arduino.
If I start the Arduino when the AC side is off, then the inbuilt LED does not glow. As soon as I switch on the AC, the inbuilt LED glows, which means that the Arduino is detecting the interrupts properly.
If I remove the digitalWrite(PIN_TRIAC, LOW) line from the interrupt service routine (ISR), the external LED glows.
This pin-points the problem to the digitalWrite(PIN_TRIAC, LOW) line in the ISR. The logic for controlling the LED is flawed somewhere.
I took the code from this website (and modified it a bit).
Have you tried turning the TRIAC on & off with software but without any "dimming"?
And you might try temporarily adding a Serial.print() statement in your ISR, and maybe print-out the millis() or micros() time to confirm it's getting triggered regularly. (Those serial print statements take some time so it might mess-up the timing when you actually start dimming.)
DVDdoug:
I did that, and I am getting a straight increasing graph from the Serial plotter, which means that the ISR is being called regularly.
An LED without a diode in series with it that is connected to an AC source will likely fail due to the reverse voltage. Get a new LED and put a 1N4148 or 1N400x in series with it along with the resistor. Connect it to the transformer output first to test.
I wonder if the ~20uS on pulse on your ISR is too short; perhaps the current flow in the LED is not instantaneous and by the time the 20uS period is finished there's not enough current flowing to sustain the triac in the on-state.
I feel like you might want to change the drive so that the gate drive lasts from your turn on point to a short period of time before the next zero-crossing. Can you try changing that 20uS delay to, say, 3mS (you start at 5mS and should have 5mS before the next zero-cross so it should go off in time for the next zero cross event...)
I don't think the pulse you're getting is based on a true zero crossing. The H11AA1 is connected to create a normally high signal but I can't see any pulldown resistor for the emitter. Are you sure you don't want to do something like this where you would detect the rising signal (this is more common on the web) ...
WattsThat:
As I have said before, the LED glows fine if I connect the "A" terminal of the MOC3052 directly to 5V, so the LED is probably working fine.
Blackfin:
delayMIcroseconds() is derived from micros() which is based on millis() which is based on a timer interrupt so this function may simply not work inside your ISR (the function zeroCrossion() is an ISR), as interrupts are off as long as you are in that ISR. You have to keep that function as quick and short as possible, so other interrupts can be serviced. It also helps keeping your overall sketch responsive.
You best use timer interrupts for this. So upon ZC your zeroCrossing() function set a timer interrupt to the moment you want to switch on the TRIAC (on an Uno use timer1 or timer2, this as timer0 is taken by the millis() function and rolls over every ~1 ms), then in that function set a new timer interrupt for when you want to switch off the signal again.
See also this simple example on the unfortunately discontinued Arduino playground.
wvmarle:
I read about timer interrupts some time back, and they seemed to be a bit perplexing. I will check out the example you linked.
I replaced the 6V transformer with a 9V one, and now the LED is glowing very faintly at some specific values of the two delays. So, it could be an issue of the series resistance — maybe it is too high and the LED is not glowing because of that. Also, at some values, the LED is glowing brightly, but blinking continuously.
wvmarle:
delayMIcroseconds() is derived from micros()...
Are you sure? From wiring.cpp, delayMicroseconds just appears to burn machine cycles, at least for AVR processors. The source (condensed down to the 16MHz F_CPU case):
void delayMicroseconds(unsigned int us)
// for the 16 MHz clock on most Arduino boards
// for a one-microsecond delay, simply return. the overhead
// of the function call takes 14 (16) cycles, which is 1us
if (us <= 1) return; // = 3 cycles, (4 when true)
// the following loop takes 1/4 of a microsecond (4 cycles)
// per iteration, so execute it four times for each microsecond of
// delay requested.
us <<= 2; // x4 us, = 4 cycles
// account for the time taken in the preceeding commands.
// we just burned 19 (21) cycles above, remove 5, (5*4=20)
// us is at least 8 so we can substract 5
us -= 5; // = 2 cycles,
// busy wait
__asm__ __volatile__ (
"1: sbiw %0,1" "\n\t" // 2 cycles
"brne 1b" : "=w" (us) : "0" (us) // 2 cycles
// return = 4 cycles
which is roughly equivalent to:
void delayMicroseconds( unsigned int us )
if( us <= 1 )
return;
us = (us * 4) - 5;
while( us )
us--;
return;
I agree that the timing for the dimming should be done using timer interrupts rather than any delay inside a pin interrupt ISR.
@OP, did you use delayMicroseconds( 3000 ) or another method of delay (e.g. delay(3) which would not work...)?
With the 6V transformer replaced with a 9V one, the following two code snippets work partially:
Yeah, the higher the AC Voltage, the closer the pulse can be to the true zero-cross. Probably the code was developed with a 120VAC or 220VAC input circuit. Anyways, using a transformer is safer, but if the voltage is too low, the Vf of the IRLED (probably 1.4V) takes up a huge portion of the 6VAC signal. Additionally, it takes a certain current through the IRLED to generate the pulse ... maybe this would be at at 4V (depends on the series resistor value). Sure would be nice to actually see your schematic. Lowering the series resistor value (which I can't see) to the IRLED would probably help, or increasing the voltage (as you have found).
It starts to sound like the TRIAC switches off the moment the input pulse is switched off, the current drawn by a single LED may not be enough to latch it on.
