Direct port manipulation
hello! I am trying to speed up a timer whereby a sensor takes Nano D10 low to start and D11 low to stop.
I (think) I have figured out digitalWrite setup( although that probably wont help speed up?) but cannot figure out how to replace digitalRead with direct port addressing......
THANKS
float elap ;
float X = 0;
unsigned long time1;
unsigned long time2;
#define firstsensor_1 10   //D10 input pin
#define secondsensor_2 11  //D11 input pin
  // pinMode (firstsensor_1, INPUT);
  //pinMode (secondsensor_2, INPUT);
  //digitalWrite(firstsensor_1, HIGH);
  //digitalWrite(secondsensor_2, HIGH);
  DDRB = B11110011;
  PORTB = B00001100;
  while (digitalRead(firstsensor_1) == 0);
  while (digitalRead(firstsensor_1));
  time1 = micros();
  while (digitalRead(secondsensor_2));
  time2 = micros();
  elap = time2 - time1;
  X = 196850 / elap;
  Serial.print(X);  //serialmonitor check
Read this:
PORTx will write the whole port. You already use this in setup.
PINx will read the whole port.
take a look here: Arduino Reference - Arduino Reference
To get the reading of one input pin you "grab" the appropriate bit.
For example (Arduino UNO or NANO):
  x = (PIND & bit (0)) == 0;   // digitalRead (0);
  x = (PIND & bit (1)) == 0;   // digitalRead (1);
  x = (PIND & bit (2)) == 0;   // digitalRead (2);
  x = (PIND & bit (3)) == 0;   // digitalRead (3);
  x = (PIND & bit (4)) == 0;   // digitalRead (4);
  x = (PIND & bit (5)) == 0;   // digitalRead (5);
  x = (PIND & bit (6)) == 0;   // digitalRead (6);
  x = (PIND & bit (7)) == 0;   // digitalRead (7);
  x = (PINB & bit (0)) == 0;   // digitalRead (8);
  x = (PINB & bit (1)) == 0;   // digitalRead (9);
  x = (PINB & bit (2)) == 0;   // digitalRead (10);
  x = (PINB & bit (3)) == 0;   // digitalRead (11);
  x = (PINB & bit (4)) == 0;   // digitalRead (12);
  x = (PINB & bit (5)) == 0;   // digitalRead (13);
  x = (PINC & bit (0)) == 0;   // digitalRead (A0);
  x = (PINC & bit (1)) == 0;   // digitalRead (A1);
  x = (PINC & bit (2)) == 0;   // digitalRead (A2);
  x = (PINC & bit (3)) == 0;   // digitalRead (A3);
  x = (PINC & bit (4)) == 0;   // digitalRead (A4);
  x = (PINC & bit (5)) == 0;   // digitalRead (A5);
Thanks U2, I had already read your reference, but still cannot see how I replace digitalRead in my example ?
jetstuff:
Do you understand D10 is bit port B bit 2 and D11 port B bit 3 ?
If so, what does this do ?
if(PINB & bit (2)) == 0)
Thanks! I think I've got it.....I needed to put some extra brackets in the first 'while' to get it to compile is that OK??
Now if I run the new program with D11 held low and initiating by taking D10 low to record time I get 5049212.... whereas before it would give 2524606....? so it seems exactly double??
ElapTime is .004... was.008 so twice as fast! interesting. The program byte size has hardly reduced though.... I was expecting more.
float elap ;
float X = 0;
  DDRB = B11110011;
  PORTB = B00001100;
  //while (digitalRead(firstsensor_1)==0);
  //while (digitalRead(firstsensor_1));
  while ((PINB & bit (2)) == 0);
  while (PINB & bit (2));
  time1 = micros();
  //while (digitalRead(secondsensor_2));
  while (PINB & bit(3));
  time2 = micros();
  X = 196850 / elap;
Thanks 'George', but a few words would be preferable to more Arduino website links.
jetstuff:
Well, they link to the right words, so what is your problem? Documentation exists so people don't have to yadda yadda all the time.
I was just looking for confirmation that the sketch that I have written is 'OK', it works, but is it 'correct' , website links don't help to answer my query.
Thanks everyone anyway, I'm sure its very clear to 'Anne Expert'
What does this division do?
X = 196850 / elap;
Smaller (i.e. quicker) would make X bigger.
I would think that elap is the number you are looking for.
jetstuff:
In fact, the documentation is absolutely the right place to find out whether what you're doing is correct. All you can get in a forum are educated opinions. You should eschew the sarcastic name calling, it makes you appear very immature.
CrossRoads:
X = 196850 / elap;
Thanks Crossroads, yes elap time exactly halved which made me suspicious that I have done something wrong in the program. I was also expecting some size reduction after getting rid of digitalRead, (but that's not a problem).
The 196850 just relates to distance between start/stop sensors.
Thanks aarg, I'm an immature 72 year old Python fan....but not the sort your thinking of :slight_smile:
aarg:
Why are you using (or trying to use) while ?
I'm not an experienced coder, I just cobble together bits that work for me. Its a program that has worked well previously, I was just trying to speed it up for better timing accuracy, I didn't want to re-invent it, just speed it up by getting rid of digitalRead. Do you think there is a better option?
I think programming is fun, for me it's not a chore. I don't do it professionally.
I posted the links to while and do while to help you.
To "read a pin", whether by PINB or digitalRead, then just do it.
pinState = digitalRead(sensorpin);
OR
pinState = PINB & (3);
This would read pin0 and pin1
maybe you meant
pinState = PINB & (1<<3);
Note that sketches that depend on testing for (pinState == 1) or (pinState == HIGH) instead of testing for non-zero, will fail for the above code.
So, this digitalReads pin 11 and reports the result on pin 13.
(When 11 is Grounded, the LED goes Off.)
const byte testIn = 11;
byte result;
  pinMode (13, OUTPUT);
  pinMode (testIn,INPUT_PULLUP);
  result = (PINB & B00001000);
  if(result == 0)
    PORTB = PORTB & B11011111;  // PORTB = PORTB & bit(3)
    PORTB = PORTB | B00100000;
