There is a way to disable CDC on the Native port for the Arduino Zero?
I have a problem listing both endpoint as CDC instead HID
COM29 is the CDC and COM30 is the HID.
I tried to use -DCDC_DISABLED but i just get this error
C:\Users\nuyel\AppData\Local\Temp\arduino-sketch-E625889ECD94B1BD0E8C3A03A42661E3/core\core.a(USBCore.cpp.o): In function `USBDeviceClass::ISRHandler()':
C:\Users\nuyel\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino\USB/USBCore.cpp:921: undefined reference to `Serial_::handleEndpoint(int)'
C:\Users\nuyel\AppData\Local\Arduino15\packages\arduino\hardware\samd\1.8.13\cores\arduino\USB/SAMD21_USBDevice.h:109: undefined reference to `SerialUSB'
collect2.exe: error: ld returned 1 exit status
If I manually change the driver to HID works, but the plan is make a PnP shortcut keys and this just make errors.
