Disabled code to greyed out
Hello,
Is it possible with Arduino IDE 2 to display disabled lines of code (ie: through #define/#ifdef) as greyed out lines?
Thank you
If the editor had to in effect carry out a compile every time you pressed a key, it might slow down a bit.
Remember the results of an #ifdef might depend on defines in other files that may or may not be #included
You are right, but Arduino IDE 2 seems to be based on vscode where highlight syntaxis to greyed out for #define works fine there.
Is it possible to enable it to give it a try?
I have a project with several configurations through #define switches and it is crazy to edit without greyed out highlight syntaxis.
It works with vscode + Arduino_extension, but I would prefer to use Arduino IDE 2.
