cyclegadget:
I am working with K-line that is similar to yours. My code starts the bit-bang before activating the UART1.
I am using UART0 for debug. This is on a 1284 chip.
digitalWrite (TX, HIGH); // makes K-line high 3
digitalWrite(ledPin,HIGH);
delay(2000); // wait for K-line to be clear 3
digitalWrite (TX, LOW); // makes K-line low 3
delay(25);
delay(25); //last delay before first message
Serial1.begin(10400);
Also, I think there is a function called Serial.end() to stop serial comms.. I am not positive about it though.
Hi I used this code on the Leonardo for Lin,
int ledState = LOW; // ledState used to set the LED
long previousMillis = 0; // will store last time LED was updated
long interval = 250;
//Lin Initailisation
#define linspeed 19200
unsigned long Tbit = 1000000/linspeed;
#define uartlenght 10
//Tbits Header
#define breakfield 13
#define breakdelimiter 1
#define breakfieldinterbytespace 2
int frameerrordelay = ((breakfield + breakdelimiter) - uartlenght)*Tbit;
//int frameerrordelay = (breakfield + breakdelimiter + breakfieldinterbytespace) - uartlenght;
#define syncfield uartlenght
#define PIDfield uartlenght
#define syncfieldPIDinterbytedelay 0
int syncfieldPIDinterbytespace = syncfieldPIDinterbytedelay*Tbit;
//Tbit Response
#define responsedelay 8
int responsespace = responsedelay*Tbit;
#define interbytedelay 0
int interbytespace = interbytedelay*Tbit;
#define numbers 4
byte message[numbers],sending[numbers];
byte linb,sync,PID,checksum;
int n = 0;
// initialize serial port and LIN:
Serial.begin(19200);
Lininit();
pinMode(13, OUTPUT);
blinking();
LinReading();
// LinWriting();
void LinReading() {
LinRead();
PrintlnLin();
ClearFrame();
void LinWriting() {
LinWrite(sending);
Answer();
void Lininit() {
Serial1.begin(linspeed);
pinMode(0,INPUT_PULLUP);
void Answer() {
for (int i=0;i<numbers;i++) {
sending[i] = n;
n++;
n = n % 256;
Serial.println(n,HEX);
void LinRead() {
if (1<<FE1) {
delayMicroseconds(frameerrordelay); //after Frame Error Tbit to Sync Field
if (Serial1.available() > 0) {
sync = Serial1.read();
if (sync != 0x55) {
sync = 0x00;
delayMicroseconds(syncfieldPIDinterbytespace); //Interbyte Space
PID = Serial1.read();
delayMicroseconds(responsespace); //after PID Tbit space
message[i] = Serial1.read();
if (interbytespace == 0) { //Interbyte Space
delayMicroseconds(1);
delayMicroseconds(interbytespace);
checksum = Serial1.read();
Serial.println("NO Break");
void LinResponse(byte* sending) {
if (1<<FE1) {
if (sync == 0x55) {
if (PID == 0x11) {
Serial1.write(sending[i]);
Serial1.write(MessageCRC(message,0));
void LinWrite(byte* sending) {
Serial1.end();
pinMode(0,OUTPUT);
digitalWrite(1, LOW);
delayMicroseconds(breakfield*Tbit); //after Frame Error Tbit to Sync Field
digitalWrite(1, HIGH);
delayMicroseconds(breakdelimiter*Tbit);
Serial1.write(0x55);
Serial1.write(0x03);
Serial1.write(MessageCRC(sending,0));
void PrintlnLin() {
if(sync != 0) {
// Serial.print("Break Field Sync: ");
// Serial.print(sync,HEX);
Serial.print("PID: ");
Serial.print(PID & 0x3F,HEX); //PID without CRC
Serial.print(" CRC: ");
Serial.print(PIDCRC(PID));
Serial.print(" Message: ");
Serial.print(message[i],HEX);
Serial.print(";");
Serial.print(" Checksum: ");
Serial.print(checksum,HEX);
Serial.print(" ChecksumCRC: ");
Serial.println(MessageCRC(message,0),HEX);
void ClearFrame() {
sync = 0;
PID = 0;
message[i] = 0;
checksum = 0;
void blinking() {
if(currentMillis - previousMillis > interval) {
// save the last time you blinked the LED
// if the LED is off turn it on and vice-versa:
if (ledState == LOW)
ledState = HIGH;
ledState = LOW;
// set the LED with the ledState of the variable:
digitalWrite(13, ledState);
int PIDCRC(int PID) {
int P0 = ((PID>>0) + (PID>>1) + (PID>>2) + (PID>>4)) & 1;
int P1 = ~((PID>>1) + (PID>>3) + (PID>>4) + (PID>>5)) & 1;
return (P0 | (P1<<1));
byte MessageCRC(byte* message, uint16_t sum) {
sum += message[i];
while(sum>>8) // In case adding the carry causes another carry
sum = (sum&255)+(sum>>8);
return (~sum);
And for the Due I have Isolated and changed the Atmel Framework Examplecode. I will attach it but I have at the moment not the time for tests also I had also to comment out the USART1_Handler in the variant.cpp to let it complie proper.
B.R.
Markus
Lin_am_Due_final.zip (36.6 KB)
