I am using an Arduino Mega 2560 ADK, which has a built-in USB host controller (MAX3421E), to connect a USB barcode scanner.
Here is a picture of the board I am using: Arduino Mega 2560 ADK. It indeed has a built-in USB host controller (MAX3421E):
My goal is to read barcodes from the scanner and display them on the Serial Monitor, as it is essential for my project to interface it through the Arduino Mega 2560 ADK's built-in USB port. I have connected an external 9V power supply to ensure sufficient power. However, I encounter an issue where the initialization of the USB host controller sometimes fails with the error: "OSC did not start." Even when the initialization passes, I do not see any output from the barcode scanner. I have included my code below and would appreciate any guidance or sample code to successfully read barcodes using the built-in USB port on the Arduino Mega 2560 ADK.
#include <hid.h>
#include <usbhub.h>
#include <hiduniversal.h>
#include <hidboot.h>
// Satisfy IDE, which only needs to see the include statment in the ino.
#ifdef dobogusinclude
#include <spi4teensy3.h>
#include <SPI.h>
#endif
char scan;
class MyParser : public HIDReportParser {
public:
MyParser();
void Parse(HID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf);
protected:
uint8_t KeyToAscii(bool upper, uint8_t mod, uint8_t key);
virtual void OnKeyScanned(bool upper, uint8_t mod, uint8_t key);
virtual void OnScanFinished();
MyParser::MyParser() {}
void MyParser::Parse(HID *hid, bool is_rpt_id, uint8_t len, uint8_t *buf) {
if (buf[2] == 1 || buf[2] == 0) return;
for (uint8_t i = 7; i >= 2; i--) {
if (buf[i] == 0) continue;
if (buf[i] == UHS_HID_BOOT_KEY_ENTER) {
OnScanFinished();
else {
OnKeyScanned(i > 2, buf, buf[i]);
return;
uint8_t MyParser::KeyToAscii(bool upper, uint8_t mod, uint8_t key) {
if (VALUE_WITHIN(key, 0x04, 0x1d)) {
if (upper) return (key - 4 + 'A');
else return (key - 4 + 'a');
else if (VALUE_WITHIN(key, 0x1e, 0x27)) {
return ((key == UHS_HID_BOOT_KEY_ZERO) ? '0' : key - 0x1e + '1');
return 0;
void MyParser::OnKeyScanned(bool upper, uint8_t mod, uint8_t key) {
uint8_t ascii = KeyToAscii(upper, mod, key);
Serial.print((char)ascii);
scan = (char)ascii;
void MyParser::OnScanFinished() {
Serial.println(" - Finished");
USB Usb;
USBHub Hub(&Usb);
HIDUniversal Hid(&Usb);
MyParser Parser;
Serial.begin( 9600 );
Serial.println("Start");
while (Usb.Init() == -1) {
Serial.println("OSC did not start.");
delay( 1000 );
delay( 200 );
Hid.SetReportParser(0, &Parser);
Usb.Task();
Any help or suggestions on how to resolve the initialization issue or improve my code to successfully read barcodes would be greatly appreciated. Thank you!
