DISPARO DE 2 TRIACS
Buenos días.
Mediante un zero crossing de una señal 220V AC quería controlar el disparo de 2 TRIACS para conectar a cada triac 1 bombilla de 220V (pudiendo variar su valor desde 0V a 220V).
Me gustaría que una bombilla tuviese un valor (elegido por nosotros mediante el disparo del triac antes o despues en el semiperiodo de la onda de 220V) independiente de la otra bombilla.
He encontrado este código de programa pero usa TIMERS Y COUNTERS y tras mirar el DATA SHEET del ATMEGA 328 no consigo entender el código:
// AC Control V1.1
// This Arduino sketch is for use with the heater
// control circuit board which includes a zero
// crossing detect function and an opto-isolated TRIAC.
// AC Phase control is accomplished using the internal
// hardware timer1 in the Arduino
// Timing Sequence
// * timer is set up but disabled
// * zero crossing detected on pin 2
// * timer starts counting from zero
// * comparator set to "delay to on" value
// * counter reaches comparator value
// * comparator ISR turns on TRIAC gate
// * counter set to overflow - pulse width
// * counter reaches overflow
// * overflow ISR turns off TRIAC gate
// * TRIAC stops conducting at next zero cross
// The hardware timer runs at 16MHz. Using a
// divide by 256 on the counter each count is
// 16 microseconds.  1/2 wave of a 60Hz AC signal
// is about 520 counts (8,333 microseconds).
#include <avr/io.h>
#include <avr/interrupt.h>
#define DETECT 2  //zero cross detect
#define GATE 9    //TRIAC gate
#define PULSE 4   //trigger pulse width (counts)
int i=483;
void setup(){
  // set up pins
  pinMode(DETECT, INPUT);     //zero cross detect
  digitalWrite(DETECT, HIGH); //enable pull-up resistor
  pinMode(GATE, OUTPUT);      //TRIAC gate control
  // set up Timer1
  OCR1A = 100;      //initialize the comparator
  TIMSK1 = 0x03;    //enable comparator A and overflow interrupts
  TCCR1A = 0x00;    //timer control registers set for
  TCCR1B = 0x00;    //normal operation, timer disabled
  // set up zero crossing interrupt
  attachInterrupt(0,zeroCrossingInterrupt, RISING);
    //IRQ0 is pin 2. Call zeroCrossingInterrupt
    //on rising signal
//Interrupt Service Routines
void zeroCrossingInterrupt(){ //zero cross detect
  TCCR1B=0x04; //start timer with divide by 256 input
  TCNT1 = 0;   //reset timer - count from zero
ISR(TIMER1_COMPA_vect){ //comparator match
  digitalWrite(GATE,HIGH);  //set TRIAC gate to high
  TCNT1 = 65536-PULSE;      //trigger pulse width
ISR(TIMER1_OVF_vect){ //timer1 overflow
  digitalWrite(GATE,LOW); //turn off TRIAC gate
  TCCR1B = 0x00;          //disable timer stopd unintended triggers
void loop(){ // sample code to exercise the circuit
i--;
OCR1A = i;     //set the compare register brightness desired.
if (i<65){i=483;}
delay(15);
Tambien adjunto la imagen del circuito.
Alguien podría explicarmelo de forma sencilla como colocar en este programa un segundo TRIAC?
Muchas gracias,
Un saludo.
Moderador: Imagen editada
Tranquilo si no me ofendo porque tienes razón en parte, se cual es la función de ese código, lo que no entiendo son las partes de "OCR1A, TIMSK1, TCCR1A, TCCR1B y TCNT1"
Y si la libreria de interrupciones si que la comprendo más o menos, vi esa página que mandaste.
pero mi duda concreta era que ese codigo sirve para controlar el disparo de UN TRIAC, pues quiero modificar ese código para controlar el disparo de DOS TRIACs.
Gracias por tu respuesta.
Esto es lo que controla el disparo de un triac.
No dices como quieres que se controle el 2do?
Controlar dos sería tan simple como agregar las instrucciones para el 2do y listo.
Pues esa es mi duda, como agregar esas instrucciones para el segundo triac y que pueda tener distinto valor que el primer triac, es decir, por ejemplo si al disparar el primer triac conseguimos una tension de salida de 120V, que pueda haber un disparo diferente en el segundo triac y conseguir una tension de salida de 200V por ejemplo.
Moderador: Editado. No repitas lo que se lee en el post anterior.
