So it appears this uses the standard HD77480 driver chip
No, it uses two of them, hence the extra enable line.
(and therefore just the normal library).
No, the board has two enable lines so it needs a modified library.
BUT - the LiquidCrystal440 library was written for the old Arduino IDE (pre v1.0). There is an updated library available at the same place he found this one. I am on vacation now and do not have the link available on this computer.
Hey DEAFBOY. I just received my 40x4. I cant really figure out where the pins go on my Arduino Mega. I see you use a UNO...but woud it be possible to post your pinouts please ? I wish to try out your sketch that will help me figure out how to do it with a MEAG. Thx !
I have 3, 40x4 displays but they are TM404ABA1 models
They have 8 smaller chips (OKI M5259 54542B21) soldered to the rear as well as 2 large chips (SEC 527 KS0066F05)
The only data I can find on these is a single page datasheet that has a pinout only. Apparently they are made for medical and industrial equipment and cost a lot more than the usual 40x4 displays described above. I will try the libraries mentioned here but I have some doubts as to compatibility because of the chips on the rear that are not found on other 40x4 displays.
Has anyone had any experience with these displays please?
