Display address of a DS18B20 on LCD display
The goal is to display the address of a DS18B20 on LCD display. Parts: Nano, 20 * 4 LCD display, and 1602 LCD Display IIC I2C Adapter IIC Serial Interface Adapter. Some code used from Arduino 1-Wire Address Finder . The problem is 5th, 6th, and 7th set of numbers get shortened to 3 digits, when they should be 4 digits. See picture.
The correct address for this sensor is 0x28, 0xB7, 0x25, 0x2A, 0xOD, 0x00, 0x00, 0xCD . The display works properly with other sketchs.
DS18B20.ino (1.1 KB)
lcd.print("0x");
if( addr[i] < 0x10)
  lcd.print( "0");
lcd.print(addr[i], HEX);
sprintf can be used to format complete strings for display on an LCD
byte addr [] = { 0x28, 0xB7, 0x25, 0x2A, 0x0D, 0x00, 0x00, 0xCD };
char s [80];
void
setup ()
    Serial.begin (9600);
    sprintf (s, " %02x %02x %02x %02x %02x %02x %02x %02x",
        addr [0], addr [1], addr [2], addr [3],
        addr [4], addr [5], addr [6], addr [7] );
    Serial.println (s);
    sprintf (s, " 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x 0x%02x",
    Serial.println (s);
    sprintf (s, " 0x%02x 0x%02x 0x%02x 0x%02x",
        addr [0], addr [1], addr [2], addr [3]);
    Serial.println (s);
        addr [4], addr [5], addr [6], addr [7]);
    Serial.println (s);
void
loop ()
outputs
 28 b7 25 2a 0d 00 00 cd
 0x28 0xb7 0x25 0x2a 0x0d 0x00 0x00 0xcd
 0x28 0xb7 0x25 0x2a
 0x0d 0x00 0x00 0xcd
Thank you very much! Worked
Thank you for explaining sprintf. Good lesson.
