Hi everyone,
I am new to mechatronics and I am building a 2WD car which can be controlled with a XY-axis joystick. Currently everything works.
BOM:
- Ardunio UNO
- L298N H-Bridge
- LCD with I2C module
- Simple XY-Axis joystick
- 2x DC motors geared with Encoder on the shaft (see picture below)
Connections are all good. The car is moving as it should move.
The question here is, how can i display the RPM (Speed) on the display using these encoders on the motors?
I have connected the pins from the encoder like on the picture below (for both motors on pin 2 and ~3 of the arduino.
CODE
#define enA 9
#define in1 4
#define in2 5
#define enB 10
#define in3 6
#define in4 7
// Library voor de LCD met I2C module (deze module zorgt er voor dat je maar 4 jumperkabels nodig hebt ipv 8)
#include <Wire.h>
LiquidCrystal_I2C lcd(0x27,16,2);
int motorSpeedA = 0;
int motorSpeedB = 0;
pinMode(enA, OUTPUT);
pinMode(enB, OUTPUT);
pinMode(in1, OUTPUT);
pinMode(in2, OUTPUT);
pinMode(in3, OUTPUT);
pinMode(in4, OUTPUT);
// Initialiseren LCD scherm
lcd.init();
lcd.init();
// Display een bericht op de LCD
lcd.backlight();
lcd.setCursor(1,0);
lcd.print("MR.BEAN");
lcd.setCursor(1,1);
lcd.print("ROBOT AUTO");
int xAxis = analogRead(A0); // Read Joysticks X-axis
int yAxis = analogRead(A1); // Read Joysticks Y-axis
// Y-axis used for forward and backward control
if (yAxis < 470) {
// Set Motor A backward
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Set Motor B backward
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Convert the declining Y-axis readings for going backward from 470 to 0 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(yAxis, 470, 0, 0, 255);
motorSpeedB = map(yAxis, 470, 0, 0, 255);
else if (yAxis > 550) {
// Set Motor A forward
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set Motor B forward
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
// Convert the increasing Y-axis readings for going forward from 550 to 1023 into 0 to 255 value for the PWM signal for increasing the motor speed
motorSpeedA = map(yAxis, 550, 1023, 0, 255);
motorSpeedB = map(yAxis, 550, 1023, 0, 255);
// If joystick stays in middle the motors are not moving
else {
motorSpeedA = 0;
motorSpeedB = 0;
// X-axis used for left and right control
if (xAxis < 470) {
// Convert the declining X-axis readings from 470 to 0 into increasing 0 to 255 value
int xMapped = map(xAxis, 470, 0, 0, 255);
// Move to left - decrease left motor speed, increase right motor speed
motorSpeedA = motorSpeedA - xMapped;
motorSpeedB = motorSpeedB + xMapped;
// Confine the range from 0 to 255
if (motorSpeedA < 0) {
motorSpeedA = 0;
if (motorSpeedB > 255) {
motorSpeedB = 255;
if (xAxis > 550) {
// Convert the increasing X-axis readings from 550 to 1023 into 0 to 255 value
int xMapped = map(xAxis, 550, 1023, 0, 255);
// Move right - decrease right motor speed, increase left motor speed
motorSpeedA = motorSpeedA + xMapped;
motorSpeedB = motorSpeedB - xMapped;
if (motorSpeedA > 255) {
motorSpeedA = 255;
if (motorSpeedB < 0) {
motorSpeedB = 0;
// Prevent buzzing at low speeds (Adjust according to your motors. My motors couldn't start moving if PWM value was below value of 70)
if (motorSpeedA < 70) {
motorSpeedA = 0;
if (motorSpeedB < 70) {
motorSpeedB = 0;
analogWrite(enA, motorSpeedA); // Send PWM signal to motor A
analogWrite(enB, motorSpeedB); // Send PWM signal to motor B
