Hello
I have been trying for a while to show hours and minutes on a 7 segment display, obviously I have tried several methods found on google. With this program, the display clearly shows a figure on digit 4, but I can see a flicker, like it is trying to show all the figures. The problem would be the delay function?
//Common Anode Display
/* d1 a f d2 d3 b
e d dp c g d4*/
// select pin for cathode
int a = 1;
int b = 2;
int c = 3;
int d = 4;
int e = 5;
int f = 6;
int g = 7;
int dp = 8;
// select pin for anode
int d4 = 9;
int d3 = 10;
int d2 = 11;
int d1 = 12;
// set variable
long n = 1230;
int x = 100;
// Date and time functions using a DS3231 RTC connected via I2C and Wire lib
#include "RTClib.h"
RTC_DS3231 rtc;
int hours, minutes;
pinMode(d1, OUTPUT);
pinMode(d2, OUTPUT);
pinMode(d3, OUTPUT);
pinMode(d4, OUTPUT);
pinMode(a, OUTPUT);
pinMode(b, OUTPUT);
pinMode(c, OUTPUT);
pinMode(d, OUTPUT);
pinMode(e, OUTPUT);
pinMode(f, OUTPUT);
pinMode(g, OUTPUT);
pinMode(dp, OUTPUT);
#ifndef ESP8266
while (!Serial); // for Leonardo/Micro/Zero
#endif
delay(3000); // wait for console opening
if (! rtc.begin()) {
Serial.println("Couldn't find RTC");
while (1);
if (rtc.lostPower()) {
Serial.println("RTC lost power, lets set the time!");
// following line sets the RTC to the date & time this sketch was compiled
rtc.adjust(DateTime(F(__DATE__), F(__TIME__)));
// This line sets the RTC with an explicit date & time, for example to set
// January 21, 2014 at 3am you would call:
// rtc.adjust(DateTime(2014, 1, 21, 3, 0, 0));
DateTime now = rtc.now();
hours = now.hour();
minutes = now.minute();
int units = hours % 10;
int tens = hours / 10;
int unitss = minutes % 10;
int tenss = minutes / 10;
Serial.print(now.hour(), DEC);
Serial.print(':');
Serial.print(now.minute(), DEC);
Serial.print(':');
Serial.print(now.second(), DEC);
/*Serial.print("Temperature: ");
Serial.print(rtc.getTemperature());
Serial.println(" C");
Serial.println();*/
WeiXuan(1); pickNumber(tens);
WeiXuan(2); pickNumber(units);
WeiXuan(3); pickNumber(tenss);
WeiXuan(4); pickNumber(unitss);
delay(3000);
void WeiXuan(unsigned char m)//
switch(m)
case 1:
digitalWrite(d1,LOW);
digitalWrite(d2, HIGH);
digitalWrite(d3, HIGH);
digitalWrite(d4, HIGH);
case 2:
digitalWrite(d1, HIGH);
digitalWrite(d2, LOW);
case 3:
digitalWrite(d1,HIGH);
digitalWrite(d3, LOW);
case 4:
digitalWrite(d4, LOW);
default :
void Num_0()
digitalWrite(a, HIGH);
digitalWrite(b, HIGH);
digitalWrite(c, HIGH);
digitalWrite(d, HIGH);
digitalWrite(e, HIGH);
digitalWrite(f, HIGH);
digitalWrite(g, LOW);
digitalWrite(dp,LOW);
void Num_1()
digitalWrite(a, LOW);
digitalWrite(d, LOW);
digitalWrite(e, LOW);
digitalWrite(f, LOW);
void Num_2()
digitalWrite(c, LOW);
digitalWrite(g, HIGH);
void Num_3()
void Num_4()
void Num_5()
digitalWrite(b, LOW);
void Num_6()
void Num_7()
void Num_8()
void Num_9()
void Clear() // clear the screen
void pickNumber(unsigned char n)// select number
switch(n)
case 0:Num_0();
case 1:Num_1();
case 2:Num_2();
case 3:Num_3();
case 4:Num_4();
case 5:Num_5();
case 6:Num_6();
case 7:Num_7();
case 8:Num_8();
case 9:Num_9();
default:Clear();
/*void Display(unsigned char x, unsigned char Number)// take x as coordinate and display number
WeiXuan(x);
pickNumber(Number);
//delay(1000);
//Clear() ; // clear the screen
