~~Dissect~~ Parsing Commands
Hi! I am making a program that will move a specified motor in a specified direction and degrees. A command looks like this:
a:+20
That is supposed to move motor A 20 degrees. I think I can do the part where it moves the motor. The command could also be
b:-176
That would move motor B back 176 degrees. Does somebody know how I can get the integer and the +/-? I have done some research and can't find a good solution. Another command would be something like this:
a:+20,b:145,c:-20,d:+34,e:90,f:45, 1000
That would move 6 different motors in different directions. b:145 means to just move it to that degree and not increase or decrease it. The "1000" at the end means to wait 1000 milliseconds.
Can somebody give me a script that would work? I don't know enough about Arduino to just go off random terminology. I am currently taking a class and having massive issues, which is why I want some way to accomplish that. I cannot change the commands.
(Don't think "dissect", think "parse")
Take a look at the Serial Input Basics tutorial, which gives an overview of parsing serial data.
There are a host of simple functions in the C/C++ <string.h> library that allow all sorts of manipulations.
I would suggest to study Serial Input Basics to handle getting the command line
then try something like this to extract and parse each token
char command[] = "a:+20,b:145,c:-20,d:+34,e:90,f:45, 1000";
bool parseCommand(char * c) {
  Serial.print("Parsing ["); Serial.print(c); Serial.println("]");
  char * commaPtr = strtok(c, ",");
  while (commaPtr != nullptr) {
    Serial.print("\tToken ["); Serial.print(commaPtr); Serial.print("] -> ");
    char * colonPtr = strchr(commaPtr, ':');
    if (colonPtr != nullptr) { // we have a label
      *colonPtr = '\0';
      Serial.print("Label is '"); Serial.print(commaPtr);
      long v = strtol(colonPtr + 1, nullptr, 10); // no fancy error detection but could be done
      Serial.print("' and value is "); Serial.println(v);
    } else { // we don't have a label, it's a duration
      long d = strtol(commaPtr, nullptr, 10); // no fancy error detection but could be done
      Serial.print("duration is "); Serial.print(d);
    commaPtr = strtok(nullptr, ","); // go to next token
  parseCommand(command); // this function call will modify the command
void loop() {}
you'll see
Parsing [a:+20,b:145,c:-20,d:+34,e:90,f:45, 1000]
	Token [a:+20] -> Label is 'a' and value is 20
	Token [b:145] -> Label is 'b' and value is 145
	Token [c:-20] -> Label is 'c' and value is -20
	Token [d:+34] -> Label is 'd' and value is 34
	Token [e:90]  -> Label is 'e' and value is 90
	Token [f:45]  -> Label is 'f' and value is 45
	Token [ 1000] -> duration is 1000
the strtol() function does the heavy lifting of parsing your value and takes care of the + or - and leading spaces as well
look this over
processCmd
  0:      0 a:+20
  1:      0 b:145
  2:      0 c:-20
  3:      0 d:+34
  4:      0 e:90
  5:      0 f:45
  6:   1000  1000
vars:
  0: a     20
  1: b    145
  2: c    -20
  3: d     34
  4: e     90
  5: f     45
  6: g      0
  7: h      0
  8: i      0
  9: j      0
 wait   1000
a:123,b:456,777
processCmd
  0:      0 a:123
  1:      0 b:456
  2:    777 777
vars:
  0: a    123
  1: b    456
  2: c    -20
  3: d     34
  4: e     90
  5: f     45
  6: g      0
  7: h      0
  8: i      0
  9: j      0
 wait    777
const int Nvars = 10;
int  vars [Nvars];
int  wait;
char s [80];
#define MAX_TOKS   10
static int    _nToks;
static char * _toks [MAX_TOKS];
static int    _vals [MAX_TOKS];
int
_tokenize (
    char *s,
    const char *sep )
    int n = 0;
    for (_toks [n] = strtok (s, sep); _toks [n]; ) {
        _vals [n] = atoi (_toks [n]);
     // printf ("   %2d: %6d %s\n", n, _vals [n], _toks [n]);
        _toks [++n] = strtok (NULL, sep);
    return _nToks = n;
void
processCmd (
    const char *cmd )
    char buf [90];
    if (strlen (cmd) > sizeof(buf)-1)  {
        sprintf (s, "%s: cmd > %d", __func__, sizeof(buf)-1);
        Serial.println (s);
        return;
    Serial.println (__func__);
    strcpy (buf, cmd);
    _tokenize (buf, ",");
    for (int n = 0; n < _nToks; n++)  {
        sprintf (s, " %2d: %6d %s", n, _vals [n], _toks [n]);
        Serial.println (s);
        if (strstr (_toks [n], ":"))  {
            char c;
            int  val;
            sscanf (_toks [n], "%c:%d", &c, &val);
            int  i = c - 'a';
            if (Nvars > i)
                vars [i] = val;
        else if (n == (_nToks -1))
            wait = _vals [n];
    Serial.println ("\nvars:");
    for (int n = 0; n < Nvars; n++)  {
        sprintf (s, " %2d: %c %6d", n, 'a' + n, vars [n]);
        Serial.println (s);
    sprintf (s, " wait %6d", wait);
    Serial.println (s);
void
setup (void)
    Serial.begin (9600);
    processCmd (command);
void loop (void)
    if (Serial.available ())  {
        char buf [80];
        int  n = Serial.readBytesUntil ('\n', buf, sizeof(buf)-1);
        buf [n] = '\0';
        Serial.println (buf);
        processCmd (buf);
Thank You! That's pretty much exactly what I needed. Didn't expect such a quick response though.
Glad if it helps, make sure you understand what’ it does.
