I have a project where I need to combine two distance sensors, JSN40RT ultrasonic sensor and TF Luna LIDAR, into one circuit with an LCD. The problem that I've encountered is when the sensors is not obstructed to any object in front of it, it'll display its max distance on the LCD, but when there's an object in front of it, It should've displayed like <100cm or double digit numbers. Instead, I got 3 digit numbers and it's been stuck that way after I put an object in front of it. I can't get two digit numbers after that.
For example,
Before there's an object in front it, LCD displayed:
D1: 416 D2: 409
After an object is placed in front of it, LCD displayed:
D1: 256 D2: 239
(Should be - D1: 25 D2: 23)
Here is the function code:
void dist1(){
digitalWrite(TRIG, LOW); // Set the trigger pin to low for 2uS
delayMicroseconds(2);
digitalWrite(TRIG, HIGH); // Send a 10uS high to trigger ranging
delayMicroseconds(20);
digitalWrite(TRIG, LOW); // Send pin low again
int distance = pulseIn(ECHO, HIGH,26000); // Read in times pulse
distance= distance/58; //Convert the pulse duration to distance
//You can add other math functions to calibrate it well
lcd.setCursor(0,0);
lcd.print("D1:");
lcd.print(distance);
delay(100);
void dist2(){
if (Serial1.available()) { //check if serial port has data input
if(Serial1.read() == HEADER) { //assess data package frame header 0x59
uart[0]=HEADER;
if (Serial1.read() == HEADER) { //assess data package frame header 0x59
uart[1] = HEADER;
for (i = 2; i < 9; i++) { //save data in array
uart[i] = Serial1.read();
check = uart[0] + uart[1] + uart[2] + uart[3] + uart[4] + uart[5] + uart[6] + uart[7];
if (uart[8] == (check & 0xff)){ //verify the received data as per protocol
dist = uart[2] + uart[3] * 256; //calculate distance value
lcd.setCursor(8,0);
lcd.print("D2:");
lcd.print(dist);
delay(100);
Is there anything else I should add into the code?
so you display say 521
then you overwrite this with 30 but you did not erase the trailing 1
so what you see is 301
of course there is no color, so you can't tell that the last digit is from the previous display
print a few blank spaces after the number or clear the display before displaying a new value (check if it's the same as the previous one and don't clear the screen in that case otherwise you'll see a blinking screen)
[code]
#include <LiquidCrystal.h>
#include <SoftwareSerial.h> //header file of software serial port
SoftwareSerial Serial1(6,7); //define software serial port name as Serial1 and define pin2 as RX and pin3
String Message;
const int rs = 12, en = 11, d4 = 5, d5 = 4, d6 = 3, d7 = 2;
LiquidCrystal lcd(rs, en, d4, d5, d6, d7);
#define TRIG 8 //Module pins
#define ECHO 9
int dist; //actual distance measurements of LiDAR
int strength; //signal strength of LiDAR
float temprature;
int check; //save check value
int i;
int uart[9]; //save data measured by LiDAR
const int HEADER=0x59; //frame header of data package
Serial1.begin(115200); //set bit rate of serial port connecting LiDAR with Arduino
Serial.setTimeout(50); // default is 1 second
pinMode(TRIG, OUTPUT); // Initializing Trigger Output and Echo Input
pinMode(ECHO, INPUT_PULLUP);
delay(100);
lcd.begin(16, 2);
if (Serial.available()) {
Message = Serial.readString();
//delay(4);
dist1();
dist2();
lcd.clear();
delay(2000);
/*if(Message == "10"){
lcd.println("Speed: 10km/h");
}else if (Message == "20"){
lcd.println("Speed: 20km/h");
}else if(Message == "INVALID"){
lcd.println("NO SPEED");
Serial.println("NO SPEED");
/*lcd.setCursor(0, 1);
if(Message == "on"){
lcd.println("Speed: 10 km/h");
delay(100);
}else if(Message == "NULL"){
lcd.println("Speed: NULL");
delay(100);
void dist1(){
lcd.setCursor(0,0);
lcd.print("D1:");
delay(100);
void dist2(){
uart[0]=HEADER;
uart[1] = HEADER;
lcd.setCursor(8,0);
lcd.print("D2:");
lcd.print(dist);
Serial.println(dist); //output measure distance value of LiDAR
delay(100);
[/code]
Here is my full code. I'm still a beginner at this and am currently testing to combine them but it's messy.
I've tried adding lcd.clear() into the loop. The data displayed blinks and now I got confused.
