I have a robot car that has a 20 slot encoder wheel on the rear shaft of the motor. There is an optical encoder around the slotted wheel. I'm using a UNO and have the 2, each wheel, encoders attached to pins 2 and 3 setup as interrupts. I want to measure the distance the wheel has traveled. I got the attached sketch from the dronebotworkshop.com website. He has built the same car that I have. The sketch is just to demonstrate that the functions are working. It does a series of moves, forward, reverse, left, right then stops. He sends either the distance to travel, in centimeters, or the number of steps based on the slots in the encoder. I will eventually incorporate this logic into a maze robot but I need to be able to consistently turn the proper distance.
With the entered wheel, drive wheel not the encoder, diameter (66.1 mm) and the number of slots in the encoder (20) I should get just over 1 CM per slot. The first call to go forward has 50 CM so my wheel should go 2 1/2 revolutions, it is only going about 2/3's of a revolution. I attached an oscilloscope to the output of the encoder and get a clean square wave pulse, about a 7ms pulse with a 25 ms duty cycle. I also just had the call to go forward in the loop function and printed out the counter_A value. That showed that it is counting correctly, it counts to 50 then stops.
So the logic in the sketch works. The problem is it should take 2 1/2 revolutions to count to 50, it's only taking 2/3 a revolution. That is the problem that I am looking for help with.
Thanks
John
Robot Car with Speed Sensor Demonstration
RobotCarSpeedSensorDemo.ino
Demonstrates use of Hardware Interrupts
to control motors on Robot Car
DroneBot Workshop 2017
http://dronebotworkshop.com
// Constants for Interrupt Pins
// Change values if not using Arduino Uno
const byte MOTOR_A = 3; // Motor 2 Interrupt Pin - INT 1 - Right Motor
const byte MOTOR_B = 2; // Motor 1 Interrupt Pin - INT 0 - Left Motor
// Constant for steps in disk
const float stepcount = 20.00; // 20 Slots in disk, change if different
// Constant for wheel diameter
const float wheeldiameter = 66.10; // Wheel diameter in millimeters, change if different
// Integers for pulse counters
volatile int counter_A = 0;
volatile int counter_B = 0;
// Motor A
int enA = 10;
int in1 = 9;
int in2 = 8;
// Motor B
int enB = 5;
int in3 = 7;
int in4 = 6;
// Interrupt Service Routines
// Motor A pulse count ISR
void ISR_countA()
counter_A++; // increment Motor A counter value
// Motor B pulse count ISR
void ISR_countB()
counter_B++; // increment Motor B counter value
// Function to convert from centimeters to steps
int CMtoSteps(float cm) {
int result; // Final calculation result
float circumference = (wheeldiameter * 3.14) / 10; // Calculate wheel circumference in cm
float cm_step = circumference / stepcount; // CM per Step
float f_result = cm / cm_step; // Calculate result as a float
result = (int) f_result; // Convert to an integer (note this is NOT rounded)
return result; // End and return result
// Function to Move Forward
void MoveForward(int steps, int mspeed)
counter_A = 0; // reset counter A to zero
counter_B = 0; // reset counter B to zero
// Set Motor A forward
digitalWrite(in1, HIGH);
digitalWrite(in2, LOW);
// Set Motor B forward
digitalWrite(in3, HIGH);
digitalWrite(in4, LOW);
// Go forward until step value is reached
while (steps > counter_A && steps > counter_B) {
if (steps > counter_A) {
analogWrite(enA, mspeed);
analogWrite(enA, 0);
if (steps > counter_B) {
analogWrite(enB, mspeed);
analogWrite(enB, 0);
// Stop when done
// Function to Move in Reverse
void MoveReverse(int steps, int mspeed)
// Set Motor A reverse
digitalWrite(in1, LOW);
digitalWrite(in2, HIGH);
// Set Motor B reverse
digitalWrite(in3, LOW);
digitalWrite(in4, HIGH);
// Go in reverse until step value is reached
// Stop when done
// Function to Spin Right
void SpinRight(int steps, int mspeed)
// Go until step value is reached
// Stop when done
// Function to Spin Left
void SpinLeft(int steps, int mspeed)
// Stop when done
// Attach the Interrupts to their ISR's
attachInterrupt(digitalPinToInterrupt (MOTOR_A), ISR_countA, RISING); // Increase counter A when speed sensor pin goes High
attachInterrupt(digitalPinToInterrupt (MOTOR_B), ISR_countB, RISING); // Increase counter B when speed sensor pin goes High
// Test Motor Movement - Experiment with your own sequences here
MoveForward(CMtoSteps(50), 255); // Forward half a metre at 255 speed
delay(1000); // Wait one second
MoveReverse(10, 255); // Reverse 10 steps at 255 speed
MoveForward(10, 150); // Forward 10 steps at 150 speed
MoveReverse(CMtoSteps(25.4), 200); // Reverse 25.4 cm at 200 speed
SpinRight(20, 255); // Spin right 20 steps at 255 speed
SpinLeft(60, 175); // Spin left 60 steps at 175 speed
MoveForward(1, 255); // Forward 1 step at 255 speed
// Put whatever you want here!
