Distanse sensor HC-SR04 with LCD
Hello, i am beginner, a have sensor HC-SR04, and display. I learn how to work with sensor on random site and on the site was a code, there it is : ``
#define ECHOPIN 2
#define TRIGPIN 3
  pinMode(ECHOPIN, INPUT);
  pinMode(TRIGPIN, OUTPUT);
  digitalWrite(TRIGPIN, LOW);
  delayMicroseconds(2);
  digitalWrite(TRIGPIN, HIGH);
  delayMicroseconds(10);
  float distance = pulseIn(ECHOPIN, HIGH);
  distance = distance * 0.017315f;
  Serial.print(distance);
  Serial.print("cm\n");
  delay(1000); }
and its work,
but i want to do it not to serial monitor but on LCD, i created this code
#include <SoftwareSerial.h>
#define ECHOpin 2  // jak jsem pochopil, ECHO pin prijma signal od trig. A protoze prijma tak je to input
#define TRIGpin 3  // trig musime na ultra malou chvili zapnout a vypnout a on posle signal. OUTPUT
SoftwareSerial LCD(4, 5);
float dalka;
  pinMode(ECHOpin, INPUT);
  pinMode(TRIGpin, OUTPUT);
  LCD.begin(9600);
  delay(500);                                   //ceka na zapnuti displeje
  LCD.print("                               ");  //smaze display
  digitalWrite(TRIGpin, LOW);
  digitalWrite(TRIGpin, HIGH);  // vysle impuls do modulu na trigpin
  dalka = pulseIn(TRIGpin, HIGH);  //ted musime spocitat vzdalenost
  dalka = dalka * 0.017315f;
  LCD.write(254);
  LCD.write(128);
  LCD.print(dalka);
  LCD.print("cm\n");
  LCD.print("      ");
But on LCD is only this: 0.00 cm
Has your LCD display really got a serial interface ? Please post a link to the LCD display that you are using and a diagram of how it is connected to the Arduino
ok i bought it from here: https://learn.sparkfun.com/tutorials/pic-based-serial-enabled-character-lcd-hookup-guide#firmware-overview
ok so? its 16x2
Does the LCD.print support printing float variables?
Forget about the measurement part, and just try printing some fixed values first ...
Apparently not:
ok, but why it is not working now??
SoftwareSerial LCD(5, 6);
long dalka = 0;
  LCD.begin(9600);
  LCD.write(254);
  LCD.write(132);
  LCD.print(dalka);
  LCD.print("cm");
  dalka = dalka*0.017315; //nejaky random vzorec
  delay(200);
i connect it at pin 6,
SoftwareSerial LCD(5, 6); // pin 5 unnused
Your topic has been moved to a more suitable location on the forum.
@tom_25, do not cross-post. Other thread removed.
Ok sorry, but it's the second day and I don't know what to do
Have you written code to JUST control the LCD Display.
Get to know how to display characters and numbers, before adding the rest of your code.
Thanks.. Tom.. :grinning: :+1: :coffee: :australia:
Yes @TomGeorge there it is.
/* dysplej ma dva radky po 16 znaku, pokud dame kurzor na prvni radek a napiseme
16 znaku, 1 radek se zaplni, a pokud napiseme 17 symbolu, 1 radek se zaplni ale sedmancty symbol se da na 2. radek.
displey ma problem se zobrazovanim znaku, ulozenych v promenne*/
SoftwareSerial LCD(10, 11);  // nastavi serial, LCD, na pin 10 a 11
int pocet_zmacknuti;
boolean zmacknuto;
unsigned long casomira;
byte doba_stisku;  //limit je 25 milisekund
  pinMode(2, INPUT_PULLUP);  //tlacitko
  LCD.begin(9600);           //LCD je ted serial, a zahaji komunikaci
  delay(500);                //pocka aby se display zapl
  LCD.write(254);
  LCD.write(0x01);  //vymaze display
  casomira = millis();
  LCD.write(254);
  LCD.write(194);
  LCD.print("zmacknuto:");
  LCD.write(254);
  LCD.write(205);
  LCD.print(pocet_zmacknuti);
  while (digitalRead(2) == LOW) {  //kvuli radku 12 pullup je to yas obracene, HIGH = 0, LOW = 1
    LCD.write(254);
    LCD.write(128);
    LCD.print("Ted zmacknuto");
    zmacknuto = true;
    plus_jedna();
  if (digitalRead(2) == HIGH) {
    zmacknuto = false;
    LCD.write(254);
    LCD.write(128);
    LCD.print("                ");  //mazani "Ted zmacknuto"
  if (doba_stisku > 25) {
    pocet_zmacknuti++;
    doba_stisku = 0;
void plus_jedna() {
  if (zmacknuto == true) {
    doba_stisku = millis() - casomira;
Ok, i repair it!! there was a very bad mistake
dalka = pulseIn(ECHOpin, HIGH);
I am surprised you didn't use NewPing library to do all your ultrasonic work.
