Dividing LEDs into different groups
Hello, I wanted to ask if it is possible to make different groups in your code.
I have the following code
#include "FastLED.h"
#define NUM_LEDS 88
CRGB leds[NUM_LEDS];
#define PIN 6
  FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
  meteorRain(0xCE,0x08,0xFF,10, 50, false, 26);
void meteorRain(byte red, byte green, byte blue, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
  setAll(0,0,0);
  for(int i = 0; i < NUM_LEDS+NUM_LEDS; i++) {
    // fade brightness all LEDs one step
    for(int j=0; j<NUM_LEDS; j++) {
      if( (!meteorRandomDecay) || (random(10)>5) ) {
        fadeToBlack(j, meteorTrailDecay );
    // draw meteor
    for(int j = 0; j < meteorSize; j++) {
      if( ( i-j <NUM_LEDS) && (i-j>=0) ) {
        setPixel(i-j, red, green, blue);
    showStrip();
    delay(SpeedDelay);
void fadeToBlack(int ledNo, byte fadeValue) {
 #ifdef ADAFRUIT_NEOPIXEL_H
    // NeoPixel
    uint32_t oldColor;
    uint8_t r, g, b;
    int value;
    oldColor = strip.getPixelColor(ledNo);
    r = (oldColor & 0x00ff0000UL) >> 16;
    g = (oldColor & 0x0000ff00UL) >> 8;
    b = (oldColor & 0x000000ffUL);
    r=(r<=10)? 0 : (int) r-(r*fadeValue/256);
    g=(g<=10)? 0 : (int) g-(g*fadeValue/256);
    b=(b<=10)? 0 : (int) b-(b*fadeValue/256);
    strip.setPixelColor(ledNo, r,g,b);
 #endif
 #ifndef ADAFRUIT_NEOPIXEL_H
   // FastLED
   leds[ledNo].fadeToBlackBy( fadeValue );
 #endif
void showStrip() {
   // NeoPixel
   strip.show();
 #endif
   // FastLED
   FastLED.show();
 #endif
void setPixel(int Pixel, byte red, byte green, byte blue) {
   // NeoPixel
   strip.setPixelColor(Pixel, strip.Color(red, green, blue));
 #endif
   // FastLED
   leds[Pixel].r = red;
   leds[Pixel].g = green;
   leds[Pixel].b = blue;
 #endif
void setAll(byte red, byte green, byte blue) {
  for(int i = 0; i < NUM_LEDS; i++ ) {
    setPixel(i, red, green, blue);
  showStrip();
It's working good but I'd like to let the first and the last LED blink while the others use the animation. Can I add this? I saw that this is possible in Mu Editor where you just say group1 = and then the number of the LED and then you can define each group. However, I haven't discovered where to do that in Arduino IDE and I really want to use that programme.
There's some tricks in:
Edit: Oops, I thought that covered the CPixelView stuff, which enables using subsets of an LED array as a virtual array.
https://fastled.io/docs/group___pixel_set.html
  • leds[NUM_LEDS] we assume you know this array is where the pixel state (colour) is stored.
  • Element 0 and NUM_LEDS - 1 are the 1st and last pixels.
  • These can be updated as you need in your sketch.
You won't be able to do anything, including blinking your end LEDs while this delay is happening. It blocks all code execution until it is finished.
I deleted this line and added my blinking animation. But now everything is blinking fast and I don't have the meteor animation anymore
#define NUM_LEDS 88
#define PIN 6
// Deklaration der Funktion slowBlink vor dem Setup
void slowBlink(CRGB color, int interval);
  FastLED.addLeds<WS2811, PIN, GRB>(leds, NUM_LEDS).setCorrection(TypicalLEDStrip);
  meteorRain(CRGB(0xCE, 0x08, 0xFF), 10, 30, false, 25);
  slowBlink(CRGB(0xCE, 0x08, 0xFF), 500); // Lila Blinken für die erste und letzte LED (500 ms Intervall)
void meteorRain(CRGB color, byte meteorSize, byte meteorTrailDecay, boolean meteorRandomDecay, int SpeedDelay) {
  fill_solid(leds, NUM_LEDS, CRGB::Black);
    for(int j = 0; j < NUM_LEDS; j++) {
      if ((!meteorRandomDecay) || (random(10) > 5)) {
        leds[j].fadeToBlackBy(meteorTrailDecay);
    // draw meteor
      if ((i - j < NUM_LEDS) && (i - j >= 0)) {
        leds[i - j] = color;
    FastLED.show();
// Definition der slowBlink Funktion
void slowBlink(CRGB color, int interval) {
  static unsigned long lastUpdateTime = 0;
  static boolean state = false;
  if (millis() - lastUpdateTime >= interval) {
    lastUpdateTime = millis();
    state = !state;
    if (state) {
      // Lila für die erste LED
      leds[0] = color;
      // Lila für die letzte LED
      leds[NUM_LEDS - 1] = color;
      // LEDs ausschalten
    FastLED.show();
You need similar to this.
  • Set the animation to operate on the array pixels element 1 to NUM_LEDS - 2.
  • Update pixel states for elements 0 and NUM_LEDS - 1 (these are your flashing pixels).
  • execute strip.show(); OR FastLED.show();
You can't just delete the delay(), you have to use millis() like you did for the blinking
#define NUM_LEDS 88
#define PIN 6
  if (millis() - lastUpdateTime >= SpeedDelay) {
    fill_solid(leds + 1, NUM_LEDS - 1, CRGB::Black);
    for (int j = 1; j < NUM_LEDS - 1; j++) {
    // draw meteor
    for (int j = 0; j < meteorSize; j++) {
      if ((i - j < NUM_LEDS - 1) && (i - j >= 1)) {
    FastLED.show();
    state = !state;
    if (state) {
      leds[0] = color;
      // LEDs ausschalten
    FastLED.show();
If you replace the blocking for(int i=0... to manage it without blocking loop(), you need to add a global or static i variable and manage it explicitly. Maybe something like:
  static int i = 0;
    // draw meteor
    FastLED.show();
    ++i;
    if (i >= NUM_LEDS - 2) {
      i = 0;
