Hello everyone,
First time long time!
I have an issue that seems simple (and I'm sure it is) but it's driving me nuts. My project (On a Mega board) is reading a camera release signal from an automated 360 degree DSLR robot (Seitz Roundshot) My Arduino then sends a signal to a Nema 17 stepper motor that is part of a photographic background effect. My issue is that when I calculate a simple gear ratio (Line 80 "Ratio = Drive / Pinion") I'm getting an integer result regardless of the values of "Drive" and "Pinion". For example, For the values "Pinion = 12" and "Drive = 40" Serial Monitor gives me a result of 3.00. When I look at calculated values further down the string of calculations, this confirms that it is using a value of 3.00 and not 3.33 as it should. Any help would be much appreciated.
Here's my sketch so far.
[code]
#include <AccelStepper.h>
//Forward
const int Background_Forward = 4;
int Background_Forward_State = LOW;
//Backward
const int Background_Backward = 5;
//Reset
const int Reset_Trigger = 10;
int Reset_Trigger_State = HIGH;
const int Reset_Pin = 9;
//Alarm
const int Alarm_Pin = 6;
int Alarm_Pin_State = LOW;
const int Alarm_Speaker = 7;
int Alarm_Buzzes = 10;
int Alarm_Duration_1 = 1000;
int Alarm_Duration_2 = 2000;
//Program Duration
int Run_Speed = 200;
int Run_Acceleration = 50;
// Millis Variables
unsigned long Previous_Time_1 = 0;
unsigned long Previous_Time_2 = 0;
unsigned long Current_Time_1;
unsigned long Current_Time_2;
unsigned long Millis_Delay_1 = 1000;
//Rotation directions
int Forward = 1;
int Reverse = -1;
//Drive Variables
double Pi = 3.14159;
int Cylinder_Diameter = 112;
const int Dist_To_Background = 500;
const int Images_In_Sequence = 360;
int Image_Degrees_Turned;
double Image_Degrees_Turned_Rad;
double Degrees_Per_Image;
double Dist_Background_Moves;
double Cylinder_Circumfrence;
double Angle_Drum_Turns;
const int Pinion = 12;
const int Drive = 40;
double Ratio;
double Angle_Motor_Turns;
double Steps_Per_Degree;
int Steps_Per_Motor_Rotation = 800;
double Steps_Per_Inc;
AccelStepper stepper(1, 2, 3);
digitalWrite(Reset_Trigger, HIGH);
Cylinder_Circumfrence = Pi * Cylinder_Diameter;
Image_Degrees_Turned = 360 / Images_In_Sequence;
Image_Degrees_Turned_Rad = Image_Degrees_Turned * Pi / 180;
Dist_Background_Moves = tan(Image_Degrees_Turned_Rad) * Dist_To_Background;
Angle_Drum_Turns = (Dist_Background_Moves / Cylinder_Circumfrence) * 360;
Ratio = Drive / Pinion;
Angle_Motor_Turns = Angle_Drum_Turns * Ratio;
Steps_Per_Degree = Steps_Per_Motor_Rotation / 360;
Steps_Per_Inc = Steps_Per_Degree * Angle_Motor_Turns;
stepper.setMaxSpeed(Run_Speed);
stepper.setAcceleration(Run_Acceleration);
stepper.moveTo(Steps_Per_Inc);
pinMode(Alarm_Pin, INPUT);
pinMode(Alarm_Speaker, OUTPUT);
pinMode(Background_Forward, INPUT);
pinMode(Background_Backward, INPUT);
pinMode(Reset_Pin, INPUT);
pinMode(Reset_Trigger, OUTPUT);
Serial.print("Ratio ");
Serial.println(Ratio);
digitalRead(Background_Forward);
digitalRead(Background_Backward);
Alarm_Pin_State = digitalRead(Alarm_Pin);
Reset_Trigger_State = digitalRead(Reset_Trigger);
Increment:
Background_Forward_State = digitalRead(Background_Forward);
if ((digitalRead(Background_Forward) == HIGH) && (digitalRead(Alarm_Pin) == HIGH))
if (Alarm_Pin_State == LOW)
for (Alarm_Buzzes; Alarm_Buzzes > 0; Alarm_Buzzes--)
delay(100);
tone(Alarm_Speaker, 300);
delay(Alarm_Duration_1);
tone(Alarm_Speaker, 600);
delay(Alarm_Duration_2);
noTone(Alarm_Speaker);
delay(50);
digitalWrite(Reset_Trigger, LOW);
stepper.runToNewPosition(Steps_Per_Inc);
stepper.setCurrentPosition(0);
stepper.run();
Step_Back:
if ((digitalRead(Background_Backward) == HIGH) && (digitalRead(Alarm_Pin) == HIGH))
delay(100);
delay(50);
stepper.runToNewPosition(-Steps_Per_Inc);
stepper.run();
delay(100);
Reset:
digitalRead(Reset_Pin);
if (digitalRead(Reset_Pin) == HIGH)
[/code]
