DavidCary:
Is this sensitive enough to see any stars in the sky (other than our sun) in the daytime?
How did you think that could be done, what is your idea, and in what purpose would you like to use that?
If you want to get the temperature of the star, you need a bit different technic for that.
I wonder if this could be done by pointing the thermal camera at the sky, without any other changes to the hardware or software.
I think it would be cool to have a time-lapse movie showing the stars apparently revolving around the celestial pole for a full (24 hour) cycle.
(I don't need to get the temperature of the star for that, right?)
I've been told that the vast majority of all stars in our galaxy are red dwarfs. Most of the energy a red dwarf star emits is in the infrared.
DavidCary:
Watching the sky is one thing, telescoping the sky is one thing, but getting information from one star... Think about the problem this way; you are standing next to heat source, with IR-thermometer. It is quite large object, lets say water boiler. If the width of the object is 1 meter, and you are in the distance of two meters, what is the angle where you can turn and still hit the target. Now, go 10 meters back and turn, how much is left? Then 100m. At that point you are getting the picture of the accuracy needed for the mechanical side of the aiming. Next take 4,7 light years back, and calculate the angle.
IR-thermometer needs quite large source, or extremely hot if it small. There's no chance to get measurement with this level of technology.
Wiser men will correct my text, add extra info... and more scientic and professional information as well.
Question.. How do you think the IR sensor sold at sparkfun - MLX90614ESF-BAA - would work in your project, you specify a MLX90614ESF-DCI. I already own the one from sparkfun and was wondering if I could get away with using it?
Thanks for posting your project.
As per datasheet, xCI models are the best one, as they have the narrowest FOV and an internal "temperature gradient compensation system" which allows further narrowing.
because it wouldn't work; ordinary glass mirrors don't reflect heat (long IR).
What about surface-coated mirrors?
Glass doesn't transmit the IR well, but if it comes off the metal layer directly?
Old laser printers and scanners can be a good source of these.
Sorry about the lag in response time - I didn't see this for some reason.
I don't think a front-surface mirror would work, either; from the research I did, I never ran across anything about using a front-surface mirror, but then again everything was about the sensors and such, using special long IR transmissive lenses and elements made from something a bit more exotic than usual (thus a part of the higher price). I'm not really certain though; perhaps something to look into (if this could work, then you could potentially have a much higher scan rate, up to the limit of the sensor itself - which I understand isn't "high speed", but maybe it could be made better - hmm, I wonder what peltier cooling would do for speed?)...
Older longer wavelength thermal imagers used germanium optics (read "expensive"), but internally used mechanically-scanned facetted mirrors to produce the image across relatively few sensors.
Maybe the mirrors are simply polished metal.
I think a huge improvement will be to use a digital micromirror device capable of reflecting IR (if exists) and then go for the approach described here
I'm currently starting to build this, the sensor is on it's way. It's not -DCI but MLX90614ESF-BCF - they didn't have DCI in stock right now. But I'm trying with this and see how it goes.
One helping thing for scanning speed would be to limit the "focus"-area after the first initial scan. As I'm mostly interested in monitoring "heat buildup" during my electronics tests (for example electric vehicle conversion motor & controller), I could easily point the areas that interest me and limit the scanning around them. So to me, it would be nice to have first scan in low resolution and after that "focus" the scanning on the most heated spots either automatically or manually. That way we could get much higher scanning rate for the areas we are interested in and much lower scan rates for "background" areas.
I'm certainly going to try this when the sensor arrives.
The Cheap-Thermocam is now three times faster than before thanks to adjusting the sensors internal settings !
Additionally, I improved the software and plan to build a portable version with LCD Touchscreen, CMOS camera, SD card and lithium battery. It will be standalone from any pc as the thermal image can be viewed on the display (resolution 320x240 for the display, on the pc its highter) and later analyzed with the computer software.
@martin_bg: Thanks for the information. I currently try to understand how the compressed sensing theory is working, its not that easy @oh6kft: Have a look at my post at the other thread: Problem with Reading/Writing to the EEPROM of a MLX90614 - #6 by maxbot - Sensors - Arduino Forum . WIth the 10 degree version of the MLX90614 its hard to get comparable pictures than with the DCI (I have a BCF here..). Futureelectronics ordered about 50 new parts and they promised me that those will be available soon.
Fantastic project by the way got the rest of the parts but having a problem soucing the
MLX90614ESF-DCI is there alternative that would give the same results FutureElectronics are saying there is 22 week leadtime to get this sensor from Melexus ?
SPI-Investigator:
There is no alternative (in this price range). You can buy the sensor for 48$ plus 5$ international transportation costs by writing an email to info@as-electronic.net. This is the fastest way to get the DCI version and as far as I know the only one, too.
Thank very much for your prompt reply I had feeling there was no alternative ! I shall email the company you mention save having to wait a long time from future electronics Your help is much appriciated ! Keep up the good work.
Just an update it would appear Melexis are having some quality problems with this IR Temperature Sensors below is copy of the email I got back from them yesterday. As I already have all the parts I have emailed them back and they will let know when they have delivery date. They seem very good company to deal with !
Email from as-electronic.net
Hi Johan,
I have bad news, at the moment. We sold last week all of our stock. Melexis has quality problem with the IR Temperature sensors with the 5°FOV. We allready ordered the MLX90614ESF-DCI but we don´t have a delivery date at the moment.
I will contact you, when I get the delivery date.
