I hope someone can solve a problem I am having.
The following code works great.
do{
StepPinToggle;
Step_Delay(Pulse_Delay_Val[Mode_X][x][ 1]);
}while(++count <= 1500);
Then I changed the while statement to:
}while((digitalRead(CW_Home_Pin)) == true);
The stepper motor steps a few steps and then drops out of the do loop like it sees the home sensor.
Here is the complete program
#include "Arduino.h"
#include "PinChangeInterrupt.h"
// Define macros to make the code easer to read and speed up code excution
// by usng Port Manipulation
#define StepPinToggle PORTD ^= 0b00000010
#define StepPinFalse PORTD &= 0b11111101
#define StepPinValue PORTD & ((0b00000010) >> 1)
#define Busy_LED_On PORTC |= 0b10000000
#define Busy_LED_Off PORTC &= 0b01111111
#define INC_Step_Count(x) x += ((PORTD & 0b0000010) >> 1)
#define Reset_Step_Count(x) x = 0
#define Read_HomePin(x) digitalRead(x)
// The followng define macro checks the delay is greater then the delay
// maxi in micro seconds [1500] delay value
#define Step_Delay(x) if( x > 1500){ delay(int(x / 1000)); delayMicroseconds(int(x % 1000));} else delayMicroseconds(x)
// Debuging control
#define DEBUG 1 //Tell compiler to compile debug print statmnets (0 == dont compilen debug print || 1 == include debug print code)
#if DEBUG == 1
#define debug(x) Serial.print(x)
#define debugln(x) Serial.println(x)
#define debugF(x) Serial.print(F(x))
#define debuglnF(x) Serial.println(F(x))
#define debug_BIN(x) Serial.print(x, BIN)
#define debugln_BIN(x) Serial.println(x, BIN)
#define debug_HEX(x) Serial.print(x, HEX)
#define debugln_HEX(x) Serial.println(x, HEX)
#define debug_SerialWait while(!Serial)
#define debug_IF_Delay(x) if(x > 1500){debugF("Delay > 1500 || ");debug(int(x / 1000));debugF("mS /// "); debug(int( x % 1000));debuglnF("uS");} else{ debugF("Delay = ");debug(x);debuglnF("uS");}
#define debug_Delay(x) delay(x)}
#else
#define debug(x)
#define debugln(x)
#define debugF(x)
#define debuglnF(x)
#endif
// First defne what are PI signal pins
const byte Smack_Intensity_Pin_B4 = 18;
const byte Smack_Intensity_Pin_B3 = 19;
const byte Smack_Intensity_Pin_B2 = 20;
const byte Smack_Intensity_Pin_B1 = 21;
const byte DIR_IN_Pin = 22;
const byte Run_Pin = 23;
const byte Busy_Pin = 13;
const byte Abort_Pin = 15;
const byte ToyType_Pin_MSB = 16;
const byte ToyType_Pin_LSB = 14;
// Now define the outpins that control the DRV8825 stepper motor driver
const byte Step_Pin = 2;
const byte DIR_Out_Pin = 3;
const byte CW_Home_Pin = 12;
const byte CCW_Home_Pin = 11;
// Now define the global varables
volatile byte Home_Pin = CW_Home_Pin;
byte Toy_Type = 0;
byte Smack_Intensity_Value = 5;
volatile bool Abort_Flag = false;
uint16_t Angle_90_Count = 622;
uint16_t Angle_180_Count = 1422;
//Define macro valareables
const bool CW = false;
const bool CCW = true;
// DM8825 step divide number.. The only alowed Mode numbers are 4, 8, 16 ONLY
const byte Mode = 8; // Set up step divider
const byte Mode_Pin_0 = 10;
const byte Mode_Pin_1 = 9;
const byte Mode_Pin_2 = 7;
const byte Angle_90_Count_M2 = 78;
const byte Angle_180_Count_M2 = 178;
const uint8_t Angle_90_Count_M4 = 156;
const uint16_t Angle_180_Count_M4 = 356;
const uint16_t Angle_90_Count_M8 = 311;
const uint16_t Angle_180_Count_M8 = 711;
const uint16_t Angle_90_Count_M16 = 622;
const uint16_t Angle_180_Count_M16 = 1422;
uint8_t Mode_X = 0;
// Now define an array of the step pulse array
// Decode the Smack_Intensity to stepper motor operations
/* delay is the number of micro seconds for the require step pluse
Smack_Bottom(int 90 Degree Step Delay , int 180 Degree Step Delay)
Stepper Motor step angle is 1.8 degree which is divided by the MODE number
Mode 2 = 0.900 Deg/Step
Mode 4 = 0.450 Deg/Step
Mode 8 = 0.225 Deg/Step
Mode 16 = 0.1125 Deg/Step
Number of steps to the desired Whip-Angle equals ===>> [ (Impact-Angle - Home-Postion) / Sept-Angle ]
Angle -> 90 || 180
Mode 2 = 78 || 178
Mode 4 = 156 || 356
Mode 8 = 311 || 711
Mode 16 = 622 ||1422
Now we know how many steps to the desired angle we can now calculate the stepping rate for each intensity setting.
Step-Pulse-Width = (Swing-Time / Step-Count)
Then we divide by 2 to achive 50% duty cyvle (Step-Pulse on and off time are equal).
// Step Delay Look Up Table
// Spread Sheet .1 Seconds || 25% Strps
const unsigned long int Pulse_Delay_Val [10][4][2] =
{ // Intensity 10%
{ 4776 ,2093 }, // Mode 2 >> Angle 90 , Angle 90.
{ 2358 , 1046 }, // Mode 8 >> Angle 90 , Angle 180
{ 1198 , 524 }, // Mode 16 >> Angle 90 , Angle 180
{ 599 , 262 } // Mode 16 >> Angle 90 , Angle 180
{ // In tensity 20%
{ 3821 , 1674 },
{ 1886 , 837 },
{ 958 , 419 },
{ 479 , 210 }
{ // Intensity 30%
{ 3057 , 1339 },
{ 1509 , 670 },
{ 767 , 335 },
{ 383 , 168 }
{ // Intensity 40%
{ 2445 , 1072 },
{ 1207 , 536 },
{ 613 , 268 },
{ 307 , 134 }
{ // Intensity 50%
{ 1956 , 857 },
{ 966 , 429 },
{ 491 , 215 },
{ 245 , 107 }
{// Intensity 60%
{ 1565 , 875 },
{ 773 , 343 },
{ 393 , 172 },
{ 196 , 86 }
{ // Intensity 70%
{ 1252 , 549 },
{ 618 , 274 },
{ 314 , 137 },
{ 157 , 69 }
{ // Intensity 80%
{ 1002 , 439 },
{ 494 , 219 },
{ 251 , 110 },
{ 128 , 55 }
{ // Intensity 90%
{ 801 , 351 },
{ 396 , 176 },
{ 201 , 88 },
{ 100 , 441 }
{ // Intensity 1Q00%
{ 641 , 281 },
{ 316 , 140 },
{ 161 , 70 },
{ 80 , 35 }
void setup(){
// Initialize and start UBS for print debug points
debug_SerialWait;
// Setup and Initialize the GPIO pins
pinMode(Smack_Intensity_Pin_B4, INPUT);
pinMode(Smack_Intensity_Pin_B3, INPUT);
pinMode(Smack_Intensity_Pin_B2, INPUT);
pinMode(Smack_Intensity_Pin_B1, INPUT);
pinMode(Run_Pin, INPUT);
pinMode(Abort_Pin, INPUT);
pinMode(DIR_IN_Pin, INPUT);
pinMode(CW_Home_Pin, INPUT_PULLUP);
pinMode(CCW_Home_Pin, INPUT_PULLUP);
pinMode(ToyType_Pin_MSB, INPUT);
pinMode(ToyType_Pin_LSB, INPUT);
pinMode(Busy_Pin, OUTPUT);
pinMode(DIR_Out_Pin, OUTPUT);
pinMode(Step_Pin, OUTPUT);
pinMode(Mode_Pin_0, OUTPUT);
pinMode(Mode_Pin_1, OUTPUT);
pinMode(Mode_Pin_2, OUTPUT);
//Set output pins to defult values
StepPinFalse;
digitalWrite(DIR_Out_Pin, false);
Busy_LED_Off;
// Set the motor driver step divide number
switch (Mode){
case 2:
digitalWrite(Mode_Pin_0 , true);
digitalWrite(Mode_Pin_1 , false);
digitalWrite(Mode_Pin_2 , false);
Angle_90_Count = Angle_90_Count_M2;
Angle_180_Count = Angle_180_Count_M2;
Mode_X = 0;
case 4:
digitalWrite(Mode_Pin_0 , false);
digitalWrite(Mode_Pin_1 , true );
Angle_90_Count = Angle_90_Count_M4;
Angle_180_Count = Angle_180_Count_M4;
Mode_X = 1;
case 8:
digitalWrite(Mode_Pin_0 , true );
Angle_90_Count = Angle_90_Count_M8;
Angle_180_Count = Angle_180_Count_M8;
Mode_X = 2;
case 16:
digitalWrite(Mode_Pin_2 , true );
Angle_90_Count = Angle_90_Count_M16;
Angle_180_Count = Angle_180_Count_M16;
Mode_X = 3;
default:
debugF(" Invailed Mode Number [ ");
debug(Mode);
debugF(" ]. Vaild Mode numbers are 4, 8 or 16");
debuglnF(" Please recompile the sketch with a vailed Mode number");
do {
}while (true);
debugln();
debuglnF(" >> Set Up Complete <<");
debug(F(" Mode Number = "));
debug(Mode );
debugF("[ ");
debug(digitalRead(Mode_Pin_0));
debug(digitalRead(Mode_Pin_1));
debug(digitalRead(Mode_Pin_2));
debuglnF(" ]");
debugF("\t Mode_X >> ");
debug(Mode_X);
debugln();
debug_SerialWait;
delay(5000);
// Sytem test code
unsigned long int count = 0;
uint16_t Dir_Count = 356;
unsigned long int Delay = 140; // microSecond
uint8_t x = 0;
uint8_t Home_Pin = CCW_Home_Pin;
debug_SerialWait;
Mode_X = 0;
delay(5000);
// Mode_X = 0;
do{
debug_IF_Delay(Pulse_Delay_Val[Mode_X][x][1]);
debugF("\tMode_X >> ");
debugln(Mode_X);
debugF("\tx >> ");
debugln(x);
debuglnF("*****************");
Busy_LED_On;
StepPinFalse;
if(digitalRead(DIR_Out_Pin) == false){
for (int StepCount = 0; StepCount<1500; StepCount++) {
StepPinToggle;
else{
debuglnF("DIR Out Pin = 1");
count = 0;
do{
StepPinToggle;
// }while(++count <= 1500);
}while((digitalRead(CW_Home_Pin)) == true); << Problem here.
Busy_LED_Off;
debugF("Home sensores >> CW = ");
debug(digitalRead(CW_Home_Pin));
debugF(" || CCW = ");
debugln(Read_HomePin(CCW_Home_Pin));
if((x += digitalRead(DIR_Out_Pin)) > 9){
if( ++Mode_X > 2) Mode_X = 2;
x=0;
digitalWrite(DIR_Out_Pin,!digitalRead(DIR_Out_Pin));
// digitalWrite(DIR_Out_Pin,!digitalRead(DIR_Out_Pin));
delay(2500);
debug_SerialWait;
}while(true);
The conto\toler is ItsyBitsy 32u4 3V and the sensor is a Photo Interrupter Optical Sensor (ITR9608F). I checked the senor uninstalled an it works as expected. Even the controller dected the sensor proprly.
