Hey, I'm totally new to arduino.
I was doing the rgb led stuff following a tutorial. It worked, but I don't understand why I need these:
red = 255 - red;
green = 255 - green;
blue = 255 - blue;
The entire code is here:
Thanks!
red = 255 - red;
blue = 255 - blue;
Thanks!
Does it mean that I can say
red = 0;
green = 0;
blue = 0;
Or I even don't need to write code about their values?
Those lines only get executed if you uncomment the #define COMMON_ANODE. Without those lines, the code is designed to drive a common cathode RGB LED, where the common connection is grounded and the voltage from the output pins increases for greater brightness. With a common anode LED, the common connection goes to +5 volts, and the voltage on the output pins needs to decrease to increase the brightness. Since 255 is maximum output voltage, those lines of code are effectively inverting the amount of voltage you are outputting, so as the number goes up, the voltage decreases, and makes the common anode LED brighter.
Here is the entire code:
Adafruit Arduino - Lesson 3. RGB LED
int redPin = 11;
int greenPin = 10;
int bluePin = 9;
//uncomment this line if using a Common Anode LED
//#define COMMON_ANODE
pinMode(redPin, OUTPUT);
pinMode(greenPin, OUTPUT);
pinMode(bluePin, OUTPUT);
setColor(255, 0, 0); // red
setColor(0, 255, 0); // green
setColor(0, 0, 255); // blue
setColor(255, 255, 0); // yellow
setColor(80, 0, 80); // purple
setColor(0, 255, 255); // aqua
void setColor(int red, int green, int blue)
#ifdef COMMON_ANODE
red = 255 - red;
blue = 255 - blue;
#endif
analogWrite(redPin, red);
analogWrite(greenPin, green);
analogWrite(bluePin, blue);
Thank you!
