Hey everyone,
I am new to working with wifi and arduino, and have some questions about the code that is down below. This code is a mashup between the example code and the ESP32 library examples (ESP32 Useful Wi-Fi Library Functions (Arduino IDE) | Random Nerd Tutorials)
The project goal is that I can send a string of data to the microcontroller, which in turn controls an LED strip.
I am using a MakePico as microcontroller (mc).
My main question is:
- Every time I send 1 data point to the mc, I always get 2x Client Connect - Client Disconnect. Why does it receive it twice while I only send it once?
- And most importantly: how do I only get it to register my sent data once?
Sub questions:
- Why do I need to instantiate a new client every loop? I only use 1 device to connect to the mc
#include <WiFi.h>
// WIFI network
const char* ssid = "networkName";
const char* password = "networkPassword";
uint16_t port = 80;
// Reconnect to WIFI
unsigned long previousMillis = 0;
unsigned long interval = 30000;
// DEBUGGING TOGGLE
bool show_debug = true;
String dbug_pfx = "[DEBUG] - ";
NetworkServer server(port);
while (!Serial) {
; //wait for serial port to connect
initWiFi();
server.begin();
checkConnection();
NetworkClient client = server.accept();
if (client) { // if you get a client,
//Serial.println("New Client."); // print a message out the serial port
String currentLine = ""; // make a String to hold incoming data from the client
while (client.connected()) { // loop while the client's connected
if (client.available()) { // if there's bytes to read from the client,
char c = client.read(); // read a byte, then
//Serial.write(c); // print it out the serial monitor
if (c == '\n') { // if the byte is a newline character
// if the current line is blank, you got two newline characters in a row.
// that's the end of the client HTTP request, so send a response:
if (currentLine.length() == 0) {
// // HTTP headers always start with a response code (e.g. HTTP/1.1 200 OK)
// // and a content-type so the client knows what's coming, then a blank line:
client.println("Content-type:text/html");
client.println();
// // break out of the while loop:
} else { // if you got a newline, then clear currentLine:
//Serial.println(currentLine);
currentLine = "";
} else if (c != '\r') { // if you got anything else but a carriage return character,
currentLine += c; // add it to the end of the currentLine
client.stop();
Serial.println("Client Disconnected.");
void initWiFi() {
//WIFI_STA = Station: the ESP connects to an access point (router)
//WiFi.mode(WIFI_STA);
WiFi.begin(ssid, password);
Serial.print("Connecting to WiFi ..");
//Check for connection
// Serial.println(WiFi.status());
Serial.print('.');
Serial.print(ssid);
Serial.print(" | ");
Serial.print(WiFi.localIP());
Serial.print("RSSI: ");
Serial.println(WiFi.RSSI());
void checkConnection() {
// if WiFi is down, try reconnecting
if ((WiFi.status() != WL_CONNECTED) && (currentMillis - previousMillis >= interval)) {
Serial.print(millis());
Serial.println("Reconnecting to WiFi...");
WiFi.disconnect();
WiFi.reconnect();
