Double Slash as a text gives me silly error
Hello I've been using the ESP8266 for home automation and i run a website on it to control everything i want. I want to have a button on the website that takes me to the ip of another ESP8266 but i cant because of a bug on the Arduino IDE(Or at least i think it's a bug). I use
char webpage[] PROGMEM = R"=====(
  • Home
    to store the webpage now the thing is that i have a button that i want it to send to this ip : "//192.168.1.6" but every time i use double slash even though its text it gives me a weird error.
    Error:
    Arduino: 1.8.5 (Windows 10), Board: "Generic ESP8266 Module, 80 MHz, ck, 26 MHz, 40MHz, QIO, 512K (no SPIFFS), v2 Prebuilt (MSS=536), Disabled, None, 115200"
    C:\Users\Aggelos\Desktop\Web_UI\Web_UI_Second_ESP.ino\Web_UI_Second_ESP.ino.ino: In function 'void loop()':
    Web_UI_Second_ESP.ino:182: error: 'webthings' was not declared in this scope
    webthings();
    exit status 1
    option enabled in File -> Preferences.
    This is my Whole code:
    #include <ESP8266WiFi.h>
    #include <WiFiClientSecure.h>
    #include <ESP8266WebServer.h>
    #include <WebSocketsServer.h>
    ESP8266WebServer server;
    WebSocketsServer webSocket = WebSocketsServer(81);
    //char server[]= "www.google.com";
    int port = 443;
    WiFiClientSecure client;
    char* ssid = "AGGELOS SSID";
    char* password = "12345678900";
    Contact Info body { background-color: #333333; top: 0; left: 0; margin: 0; font-family: 'Open Sans', sans-serif; } #Header { padding: 0 30px; margin: 0; font-weight: 300; text-align: center; color: white; } #Contact { padding: 0 30px; margin: 0; font-weight: 300; text-align: center; color: white; }
    a:link{
    color: white;
    text-decoration: none;
    a:visited{
    color: white;
    a:hover{
    color: red;
    text-decoration: underline;
    a:active{
    color: grey;
    .active{
    background-color: black;
    ul {
    list-style-type: none;
    margin: 0;
    padding: 0;
    overflow: hidden;
    background-color: #333;
    li {
    float: left;
    li a {
    display: block;
    color: white;
    padding: 14px 16px;
    text-align: center;
    li a:hover {
    background-color: #111;
    .grid-container {
    display: grid;
    grid-row-gap: 20px;
    padding: 10px;
    .grid-item{
    text-align: center;
    Second Esp
    This Is A Test
    This Is A Test
    This Is A Test
    void handleRoot()
    server.send_P(200, "text/html", webpage);
    void handleNotFound()
    String message = "File Not Found\n\n";
    message += "URI: ";
    message += server.uri();
    message += "\nMethod: ";
    message += (server.method() == HTTP_GET)?"GET":"POST";
    message += "\nArguments: ";
    message += server.args();
    message += "\n";
    for (uint8_t i=0; i<server.args(); i++){
    message += " " + server.argName(i) + ": " + server.arg(i) + "\n";
    server.send(404, "text/plain", message);
    WiFi.begin(ssid,password);
    IPAddress ip(192,168,1,5);
    IPAddress gateway(192,168,1,254);
    IPAddress subnet(255,255,255,0);
    WiFi.config(ip, gateway, subnet);
    while(WiFi.status()!=WL_CONNECTED)
    Serial.print(".");
    Serial.println("");
    Serial.print("IP Address: ");
    server.on("/",{
    server.on("/home",{
    server.begin();
    webSocket.begin();
    //webSocket.onEvent(webSocketEvent);
    webthings();
    void webthings(){
    webSocket.loop();
    server.handleClient();
    if(Serial.available() > 0){
    char c[] = {(char)Serial.read()};
    webSocket.broadcastTXT(c, sizeof(c));
    We can't see your code.
    PROGMEM = R"=What's that R?
    AWOL:
    I dont actually know everyone i see on the internet is using it when storing the webpage
    How can you possibly expect to be a programmer when you are using a defective keyboard where the punctuation keys don't work?
    Why are you blindly copying and pasting code, without making ANY attempt to understand the code?
    Cite ONE example where someone posted Arduino code with R" in it.
    PaulS:
    I dont copy code this is the only way to save the webpage in flash memory I've tried different things. I know that R"=====( is kind of the only way to save the webpage.
    From what i understand you can actually use R"( SAMPLE HTML )"; too
    https://youtu.be/ROeT-gyYZfw?t=350 This is one example
    How do you "know" this?
    AWOL:
    Because ive searched the internet alot for it and ive tried many things.
    Aggeloz100:
    I'd really appreciate some firm evidence, so that I can refute it.
    AWOL:
    One example is this video you can see it at the time stamp: https://youtu.be/ROeT-gyYZfw?t=350
    And every other video of his has code like this
    It's a way to use a multicharacter delimiter for stings that allows to include line breaks without using any \n or the like.
    https://en.cppreference.com/w/cpp/language/string_literal
    Well, you live and learn.
    Thank you @Whandall for evidence, not some data plan-draining video.
    miancule:
    As for the original question - just move the void webthings(){...} function definition above the: void loop(){...} function definition and you will be fine (understanding C/C++ declarations, definitions and functions should be a must when programming in C/C++).
    You are a god thank you very much
    But here it's less of a problem, because of Arduino's automatic prototype generation.
