double the inputs double the code?
i have written a piece of code using one button as an input toggling between two outputs, it seems to work ok. here is the
/* button toggle - use one button to toggle between two outputs on different pins
   momentary push button attached to pin 2
   leds connected to pins 12 & 13
int buttonB = 2;  //button attached to pin 2
int valB;        // reads the button state in loop
int val2B;       // reads the button state a second time
int stateB;      // reads the button state in setup and stores it  could have called this button old
int pressB = 1; // press counter, i set this to 1 so when the first button is pressed it will give a value of 0 activating the first pin
int startB = 12; // led output 1
int stopB = 11; // led output 2
int button1hitB = 0;  // secondary code switch stops code running before a button has been pressed
  pinMode(buttonB, INPUT);
  pinMode(startB, OUTPUT);
  pinMode(stopB, OUTPUT);
  stateB = digitalRead(buttonB);  // read button state and store it to reference against later
void loop(){
  valB = digitalRead(buttonB);
  delay(20);          // wait 10 millis to counter debounce
  val2B = digitalRead(buttonB); //check again to see if button is pressed
  if ((valB == val2B) && (valB != stateB) && (valB == HIGH)) {
    pressB++; // counts button presses
    button1hitB = 1; //secondary code switch put in place
  if (pressB > 1) {
    pressB = 0;    //when button press count passes 1 it resets to zero
    Serial.print("press numberB");
    Serial.println (pressB);
  if (pressB == 0 && button1hitB == 1) {
    digitalWrite(startB, HIGH);
    delay (100);                  // send one pulse
    digitalWrite (startB, LOW); // then stop
    button1hitB = 0;              // wait for button to be pressed before doing anything else
  else {
    if (pressB == 1 && button1hitB == 1) {
      digitalWrite(stopB, HIGH);
      delay (100);
      digitalWrite (stopB, LOW);
      button1hitB = 0;
  stateB = valB;
i wanted to add another three buttons with the same function to the code. i started by just adding one button in first to see if i could get that to work. i duplicated the code for one button and cut and pasted it in, the result is this
int buttonA = 2;  //button attached to pin 2
int startA = 12; // led output 1 starts palying mp3
int stopA = 11; // led output 2 stops playing mp3
int valA;        // reads the button state in loop
int val2A;       // reads the button state a second time
int stateA;      // reads the button state in setup and stores it  could have called this button old
int pressA = 0; // press counter, i set this to 1 so when the first button is pressed it will give a value of 0 activating the first pin
int button1hitA = 0;  // secondary code switch stops code running before a button has been pressed
int buttonB = 10;  //button attached to pin 2
int startB = 9; // led output 1 starts palying mp3
int stopB = 8; // led output 2 stops playing mp3
int pressB = 0; // press counter, i set this to 1 so when the first button is pressed it will give a value of 0 activating the first pin
  pinMode(buttonA, INPUT);
  pinMode(startA, OUTPUT);
  pinMode(stopA, OUTPUT);
  stateA = digitalRead(buttonA);  // read button state and store it to reference against later
void loop(){
  valA = digitalRead(buttonA);
  val2A = digitalRead(buttonA); //check again to see if button is pressed
  if ((valA == val2A) && (valA != stateA) && (valA == HIGH)) {
    pressA++; // counts button presses
    button1hitA = 1; //secondary code switch put in place
  if (pressA > 1) {
    pressA = 0;    //when button press count passes 1 it resets to zero
    Serial.print("press numberA");
    Serial.println (pressA);
  if (pressB > 1) {
  if (pressA == 0 && button1hitA == 1) {
    digitalWrite(startA, HIGH);
    digitalWrite (startA, LOW); // then stop
    button1hitA = 0;              // wait for button to be pressed before doing anything else
  else {
    if (pressA == 1 && button1hitA == 1) {
      digitalWrite(stopA, HIGH);
      delay (100);
      digitalWrite (stopA, LOW);
      button1hitA = 0;
      delay (100);
      button1hitB = 0;
    stateA = valA;
    stateB = valB;
the first button toggle its output the same as it did before; one press one output another press the other output. The second button does something different; one button press and it goes through both outputs once, another press and it does the same thing.
does anyone have a suggestion of how i can change the structure of the code to allow me to add more inputs doing the same thing without distorting the original function? im sure it's probably simple i just cant see how to do it! cheers for any help.
    // Do something
     // Do something
  [glow]else {[/glow]
Is the else statement paired with the appropriate if? It does not look like it.
Whenever you start replicating code, it's time to look at arrays and functions.
You want to do something when button n is pushed. Create an array of button pins, and a function that takes a pin number as input and does the "do something" part.
thanks i'll check that out.
