Doute concernant Serial.print(floatVal, DEC);
Bonjour à tous,
J'ai une fonction que je n'ai pas écrite t qui va afficher la latitude avec 6 chiffres après le point.
printFloat(latitude, 5);
En réalisté il va afficher le nombre de virgule en fonction du deuxième paramètre. Dans cet exemple, il en affichera 5.
Voici la fonction et ma question après:
void printFloat(float value, int places) {
  // this is used to cast digits
  int digit;
  float tens = 0.1;
  int tenscount = 0;
  int i;
  float tempfloat = value;
    // make sure we round properly. this could use pow from <math.h>, but doesn't seem worth the import
  // if this rounding step isn't here, the value  54.321 prints as 54.3209
  // calculate rounding term d:   0.5/pow(10,places)
  float d = 0.5;
  if (value < 0)
    d *= -1.0;
  // divide by ten for each decimal place
  for (i = 0; i < places; i++)
    d/= 10.0;
  // this small addition, combined with truncation will round our values properly
  tempfloat +=  d;
  // first get value tens to be the large power of ten less than value
  // tenscount isn't necessary but it would be useful if you wanted to know after this how many chars the number will take
  if (value < 0)
    tempfloat *= -1.0;
  while ((tens * 10.0) <= tempfloat) {
    tens *= 10.0;
    tenscount += 1;
  // write out the negative if needed
  if (value < 0)
    Serial.print('-');
  if (tenscount == 0)
    Serial.print(0, DEC);
  for (i=0; i< tenscount; i++) {
    digit = (int) (tempfloat/tens);
    Serial.print(digit, DEC);
    tempfloat = tempfloat - ((float)digit * tens);
    tens /= 10.0;
  // if no places after decimal, stop now and return
  if (places <= 0)
    return;
  // otherwise, write the point and continue on
  Serial.print('.');
  // now write out each decimal place by shifting digits one by one into the ones place and writing the truncated value
  for (i = 0; i < places; i++) {
    tempfloat *= 10.0;
    digit = (int) tempfloat;
    Serial.print(digit,DEC);
    // once written, subtract off that digit
    tempfloat = tempfloat - (float) digit;
J'utilise un µP 32u4, donc avec un Serial1.print(). Aux pin Tx et Rx j'ai mis un OpenLog et ceci
[code]
float fl = 46.987800;
Serial1.print(F("Ecrire dans ma carte SD le float :"));
Serial1.println(fl, DESC);
Ma premiere question.
Es-ce que
Serial1.println(fl, DEC);
va ecrire la même chose que l'affichage de
Serial.println(fl, DEC);
Qu'es-ce qu'excatement le DEC? Le DEC va forcer l'affichage ou l'écriture en Décimal?
Es-ce que le DEC va me conserver les 5 chiffre après la virgule comme si je faisais
Serial.println(fl, 5);
Merci pour vos lumières!!
