Downloadable multi program "single program" i made
So app lab allows only 1 app to run at a time, so I was thinking how to work around that so you can select what you want through the web UI, will post screenshots...
I set my main program up off the offline edge assistant, and built onto that. I have vision detection available not only with a camera output on browser, but I can also Integrate the camera I to my llm chat and ask it about the images it sees!
I also created a board monitor page, that shows all types of current stats, and allows for log reading and switching app lab programs if you wanted to straight from the web ui! I have to take my network passwords out of the equation but I will try and post my stock file for this singular program because I think its feature rich and people would like it.
Also, on the llm chat, i have way more options than the stock example, you can edit about me to have the llm generate a system prompt for your session (like tell it about yourself and how you learn to get a better tailored response), and ive added 3 effort levels selectable right from. The webpage. I've updated the bugs out of the board and then built my program up to where it is now (version 2.9x)
splash page
board control and monitor page
vision page, still ran on the same app lab program, woth features for autofocus and exposure control on the usb webcam side
options on the vision page
llm chat page with options far more than the included ones
about me section, which allows better responses tailored to you until you reset the session
you can see it works great, with vision and the llm i still have headroom for more running at the same time, this board is amazingly fast and powerful, well worth the money for sure!
Also running an environmental sensor:
Heres a free starter program:
llm and vision multi program.zip (628.3 KB)
Added a port 7001 inital setup pag, stripped my personal credentials from zip file, run the boards ip@ port 7001 on first run to customize your board, then the splash page with multi controls and programs will load at port 7000, also will attach the debugging I had to do to fix my program after the board update pushed yesterday.... hope someone likes it! Feedback appericated!
-AJ
Debugging after oct/22 update: VENTUNO Q LLM update findings.txt (3.0 KB)
