I'm using an 8.4V battery pack to power an Attwood Turbo 3000 fan and a TIP41C to drive it. The circuit I'm using basically looks like this (except the diode is reversed and the Arduino ground is connected to the battery ground): http://i.imgur.com/dYAa5.png
However, I need to be able to use code to power the fan on and off at various times. This is what I wrote, but the fan is perpetually turned on, regardless:
If you have a diode across the transistor's c-e, reversed from the one in the pic, aren't you effectively shorting across there so there's always a path?
ahhreeyell:
Just a guess because I'm rusty on my electronics, but if your diode is in the wrong direction it could be shorting around your transistor thus keeping the fan on.
Do you have a meter that can check the diode? I'd suggest ANYONE playing with this stuff gets at least an inexpensive meter and learns how to use it. One of the first things I did before sending my son off to college was to get him a meter and teach him to use it.
