Hi every one, I'm not sure if this is the right spot for this topic but here goes.
I've been working on a drum kit using and old set of guitar hero drums from my old xbox and i've wired all the piezos up like todbot has them wired here : Spooky Arduino Projects #4 – Musical Arduino – todbot blog now my problem is that when i have the anologRead() function repeated to read more then two inputs, I'm using all six for the project. The arduino seems to read all the piezos as if they are being hit. But if i only read from two It functions normally. Please help me, i'm adding the source for review.
thanks Jeff
// I'm combining the knock sensor code and the midi out code to
// play the midi equivalent of a cymbol when I bang the cymbol
#define drumchan 1
#define CrashNote 49 // defining Crash ...
#define KickNote 36 // ... Kick ...
#define SnareNote 38 // ... Snare ...
#define EsnareNote 40 // ... electric Snare..
#define HatNote 46 // ... hihatopen ...
#define TomNote 43 // ... tom ...
int ledPin = 13; // this is our led pin just to visualize the notes being hit may be ommited
// setting up the anolog pins
int snare = 0;
int esnare = 1;
int tom = 2;
int hat = 3;
int cymbol = 4;
int kick = 5;
byte SnarVal = 0;
byte EsnarVal = 0;
byte TomVal = 0;
byte HatVal = 0;
byte CymAVal = 0;
byte KicVal = 0;
int statePin = LOW;
int THRESHOLD = 1;
void setup(){
pinMode (ledPin, OUTPUT);
Serial.begin(31250); // set the Serial to midi
void loop(){
SnarVal = analogRead(snare); // read the snare input
EsnarVal = analogRead(esnare); // read the esnare input
TomVal = analogRead(tom); // read the tom input
HatVal = analogRead(hat); // read the hat input
CymAVal = analogRead(cymbol); // read the cymbol input
KicVal = analogRead(kick); // read the kick input
if (SnarVal >= THRESHOLD) {
statePin = !statePin;
digitalWrite(ledPin, statePin);
noteOn(drumchan, SnareNote, 0x45); // set new note for the snare drum
delay(10);
noteOff (drumchan, SnareNote, 0);
if (EsnarVal >= THRESHOLD) {
noteOn(drumchan, EsnareNote, 0x45); // set new note for the Esnare drum
delay(10);
noteOff (drumchan, EsnareNote, 0);
if (TomVal >= THRESHOLD) {
noteOn(drumchan, TomNote, 0x45); // set new note for the Tom drum
delay(10);
noteOff (drumchan, TomNote, 0);
if (HatVal >= THRESHOLD) {
noteOn(drumchan, HatNote, 0x45); // set new note for the Hat drum
delay(10);
noteOff (drumchan, HatNote, 0);
if (CymAVal >= THRESHOLD) {
noteOn(drumchan, CrashNote ,0x45); // set new note for Crash Symbol
delay(10);
noteOff(drumchan, CrashNote, 0);
if (KicVal >= THRESHOLD) {
noteOn(drumchan, KickNote, 0x45); // set new note for the kick drum
delay(10);
noteOff (drumchan, KickNote, 0);
void noteOn(byte cmd, byte data1, byte data2){
Serial.print(cmd, BYTE);
Serial.print(data1, BYTE);
Serial.print(data2, BYTE);
// Send a MIDI note-on message. Like pressing a piano key
// channel ranges from 0-15
void noteOn(byte channel, byte note, byte velocity) {
midiMsg( (0x90 | channel), note, velocity);
// Send a MIDI note-off message. Like releasing a piano key
void noteOff(byte channel, byte note, byte velocity) {
midiMsg( (0x80 | channel), note, velocity);
// Send a general MIDI message
void midiMsg(byte cmd, byte data1, byte data2) {
digitalWrite(ledPin,HIGH); // indicate we're sending MIDI data
digitalWrite(ledPin,LOW);
