DS1030 first time read is valid, but after first, its become error
Hi just to the point, these is my code
#include <Arduino.h>
int RTCrstPin = 2;int RTCclkPin = 4;int RTCdatPin = 3;
void RTCwrite(byte address, byte data) {
    address |= 0x01;
    pinMode(RTCdatPin, OUTPUT);
    digitalWrite(RTCrstPin, HIGH);
    for (int i = 0; i < 8; i++) {
        digitalWrite(RTCdatPin, address & 0x01);
        digitalWrite(RTCclkPin, HIGH);
        digitalWrite(RTCclkPin, LOW);
        address >>= 1;
        digitalWrite(RTCdatPin, data & 0x01);
        data >>= 1;
    digitalWrite(RTCrstPin, LOW);
void RTCread(byte address) {
    address |= 0x81;
        delayMicroseconds(5);
        address >>= 1;
    pinMode(RTCdatPin, INPUT);
        Serial.print(digitalRead(RTCdatPin));
  pinMode(RTCrstPin, OUTPUT);pinMode(RTCclkPin, OUTPUT);pinMode(RTCdatPin, OUTPUT);
  Serial.begin(250000);
  RTCwrite(0x8E, 0x00);
  RTCwrite(0x80, 0x30);
  delay(100);
  RTCread(0x81);
  RTCread(0x81);
the output
*  Executing task in folder DS1302 Test: C:\Users\DayatKun0\.platformio\penv\Scripts\platformio.exe device monitor
--- Terminal on COM4 | 250000 8-N-1
--- Available filters and text transformations: colorize, debug, default, direct, hexlify, log2file, nocontrol, printable, send_on_enter, time
--- More details at https://bit.ly/pio-monitor-filters
--- Quit: Ctrl+C | Menu: Ctrl+T | Help: Ctrl+T followed by Ctrl+H
10101000
00000000
00000000
00000000
My problem is the first result that i called from setup is giving result (10101000) but the seccond and other result giving 00000000 so im thinking if the first read is work, seccond and other not, can someone help me ?? plss i coded this for 3 hour and learning this 1 week (lazy time included) and its still not workkk im trying hard for this thing, sorry im noob at coding lol, im just learning, and FYI, why did i not using library? because i wanna learning it more deeper. but as i know i followed the datasheet corectly (with some chatgpt helping).
“ The term "DS1030" appears to be a model number or part number used across various product lines. It's not associated with a single, specific datasheet. To find the correct datasheet, you'll need to know the specific product you're interested in. Possible products associated with the DS1030 designation include a Huion signing display, a GEW UV curing unit, a Dynascales belt weighing system, a Paxton access control system, and potentially others from electronics manufacturers.
Post DS1030 datasheet or link for.
here is datasheet i used.
Are you using DS1030 or DS1302?
I will try simulate your project at WOKWI.
Your problem does not sound like a problem with tool chains and therefore has been moved to a more suitable location on the forum.
Do you need to set the pin to LOW after Reading?
I could be mistaken, but the RTCs that I am familiar with have a concept of 'resetting' them after a timer is triggered. Think of a circuit breaker; when it pops, it has to be reset. Lousy analogy, but hopefully that helps.
I think you are right that preparing the address byte is a bit fishy...
i am using DS1030 module and i just realized i am using the wrong datasheet, im gonna trying using another and the correct datasheet, im gonna give you the result later.
From datasheet i saw, its look like its needed
Is this from the wrong one?
Please provide the correct datasheet.
well i just misreaded, i used the right datasheet, sorry for confusing.
i misreaded the module, my module is DS1302
