Using analog read for what?
DS1307 uses I2C for interfacing.
On Uno, that is SCL/SDA pins.
Here’s an example sketch that outputs data to the serial port.
Connect RTC to the SCL/SDA pins, use 4.7K pullup resistors to +5V.
Test of RTC DS1307 via I2C.
Counts
Seconds,
Minutes,
Hours,
Date of the Month,
Month,
Day of the week, and
Year with Leap-Year
56 bytes battery backed RAM
Square Wave Output
11/17/2012- Updated for Wire.write & Wire.read commands
1/18/13 - fixed unclear reference to 0x00
Modified to Run thru IDE Serial port
#include <Wire.h>
//variables
byte zeroByte = 0;
byte seconds_address = 0x00;
byte seconds; // bit 7 = Clock Halt, Enabled = 0, Halt = 1
// bits 6-5-3 = tens of seconds 0-6, bits 3-2-1-0 = units of seconds, 0-9
byte minutes_address = 0x01;
byte minutes; // bits 6-5-4 = tens of minutes, bits 3-2-1-0 = units of minutes
byte hours_address = 0x02;
byte hours; // 7=0. 6 = 1 for 12 hr, 0 for 24 hr.
// bit 5: 12 hr mode = AM(0)/PM(1). 24 hr mode = upper tens of hrs
// bit 4 = lower tens of hrs, bits 3-2-1-0 = units of hours (0-9)
byte day_week_address = 0x03;
byte day_week = 0; // range 01-07
byte date_month_address = 0x04;
byte date_month = 0; // range 01-31
byte month_address = 0x05;
byte month = 0; // range 01-12
byte year_address = 0x06;
int year = 0; // upper byte 0-9, lower byte 0-9
byte square_address = 0x07;
byte sqwe = 0; // square wave enable
// Out-0-0-Sqwe-0-0-RS1-RS0
// Out, Sqwe = 0/0 - Square wave output = 0
// Out, Sqwe = 1/0 - Square wave output = 1
// Out, Sqwe = 0/1 or 1/1 - Square wave output per RS1/RS0
// RS1/RS0 = 00 = 1 Hz
// RS1/RSo = 01 = 4 KHz
// RS1/RS0 = 10 = 8 KHz
// RS1/RS0 = 11 = 32 KHz
byte RTC_ram_address = 0x08; //range = 08-63, 0x08-0x3F
int RTC_address = 0x68; // 1101 000
byte incomingCommand = 0;
byte RTC_write_command = 0;
byte RTC_read_command = 0;
byte RTC_ram_command = 0;
// use F0xx, F1xx,F2xx, F3xx, F4xx, F5xx, F6xx, F7xx
// to send one register write commands
// use E0xx to read registers back - not coded yet
// use C0xx to read RAM back - not coded yet
byte incomingRegister = 0;
byte RTC_register = 0;
byte incomingData1 = 0;
byte incomingData2 = 0;
byte new_data = 0;
byte outgoingData = 0;
int delay_time = 100;
unsigned long currentMillis = 0;
unsigned long previousMillis = 0;
unsigned long duration = 5000;
Wire.begin(); // no address, we are master
Serial.begin (57600);
Serial.flush();
currentMillis = millis();
if (Serial.available() >3){
incomingCommand = Serial.read();
incomingRegister = Serial.read();
incomingData1 = Serial.read();
incomingData1 = incomingData1 - 0x30; // convert ASCII to HEX
incomingData2 = Serial.read();
incomingData2 = incomingData2 - 0x30; // convert ASCII to HEX
new_data = (incomingData1 << 4) + incomingData2; // put the Upper/Lower nibbles together
Serial.print ("command ");
Serial.println (incomingCommand);
Serial.print ("register ");
Serial.println(incomingRegister);
Serial.print ("data1 ");
Serial.println (incomingData1, HEX);
Serial.print ("data2 ");
Serial.println (incomingData2, HEX);
Serial.print ("combined data ");
Serial.println (new_data, HEX);
// RTC_write_command = incomingCommand & 0xF0; // mask off high byte
// if (RTC_write_command == 0xF0){ // check for Write command
if ((incomingCommand == 'F') | (incomingCommand == 'f')){
incomingCommand = 0; // reset for next pass
// RTC_register = incomingCommand & 0x0F; // mask off low btye
// incomingCommand = 0;
// new_data = incomingData;
Serial.println (" Sending a command ");
// switch (RTC_register){
switch (incomingRegister){
case '0': // write seconds
Serial.println ("Seconds ");
Wire.beginTransmission(RTC_address); // select device
Wire.write(seconds_address); // queue the register
Wire.write(new_data); // queue data
Wire.endTransmission(); // send it
delay (delay_time);
case '1': // write minutes
Serial.println ("Minutes ");
Wire.write(minutes_address); // queue the register
delay (delay_time);
case '2': // write hours
Serial.println ("Hours ");
Wire.write(hours_address); // queue the register
delay (delay_time);
case '3': // write day
Serial.println ("Day ");
Wire.write(day_week_address); // queue the register
delay (delay_time);
case '4': // write date of month
Serial.println ("Day of Month ");
Wire.write(date_month_address); // queue the register
delay (delay_time);
case '5': // write month
Serial.println ("Month ");
Wire.write(month_address); // queue the register
delay (delay_time);
case '6': // write year
Serial.println ("Year ");
Wire.write(year_address); // queue the register
delay (delay_time);
case '7': // write square wave
Serial.println ("Square Wave ");
Serial.println (RTC_register, HEX);
Wire.write(square_address); // queue the register
delay (delay_time);
case '8': // write RAM
Serial.print ("RAM ");
Wire.write(RTC_ram_address); // queue the register
delay (delay_time);
// all others,do nothing
Serial.println ("Invalid command ");
} // end Switch
} // end if command == 'F'
if ( (currentMillis - previousMillis) >= duration){
// Reset the register pointer
Wire.write(zeroByte);
Wire.requestFrom(RTC_address,8 );
seconds = Wire.read();
minutes = Wire.read();
hours = Wire.read();
day_week = Wire.read();
date_month = Wire.read();
year = Wire.read();
sqwe = Wire.read();
// Seconds
// Hours
Serial.print ("Hrs " );
Serial.print (hours, HEX);
Serial.print (" Mins ");
Serial.print (minutes, HEX);
Serial.print (" Secs ");
Serial.print (seconds, HEX);
Serial.print (" Day ");
Serial.print (day_week, HEX);
Serial.print (" Date ");
Serial.print (date_month, HEX);
Serial.print (" Month ");
Serial.print (month, HEX);
Serial.print (" Year 20");
Serial.print (year, HEX);
Serial.print (" Square Wave ");
Serial.println (sqwe, HEX);
