//DEfine fecha y hora
unsigned long Definehora()
unsigned long h = 0;
char key = kpd.getKey();
while(key != '#')
switch (key)
case NO_KEY:
case '0': case '1': case '2': case '3': case '4':
case '5': case '6': case '7': case '8': case '9':
h = h * 10 + (key - '0');
myGLCD.printNumI(h, 0, 40);
myGLCD.update();
case '*':
h = 0;
myGLCD.update();
key = kpd.getKey();
return h;
unsigned long Defineminutos()
unsigned long mi = 0;
while(key != '#')
switch (key)
case NO_KEY:
mi = mi * 10 + (key - '0');
myGLCD.printNumI(mi, 0, 40);
myGLCD.update();
case '*':
mi = 0;
myGLCD.update();
key = kpd.getKey();
return mi;
unsigned long Definesegundos()
unsigned long s = 0;
while(key != '#')
switch (key)
case NO_KEY:
s = s * 10 + (key - '0');
myGLCD.printNumI(s, 0, 40);
myGLCD.update();
case '*':
s = 0;
myGLCD.update();
key = kpd.getKey();
return s;
//Definicion unidades II
unsigned long Definefechahora(){
while(key != '#')
switch (key)
case NO_KEY:
case 'A':
fechahora=key;
case 'B':
fechahora=key;
key = kpd.getKey();
return fechahora;
unsigned long Definelog(){
while(key != '#')
switch (key)
case NO_KEY:
case 'A':
menulog=key;
case 'B':
menulog=key;
case 'C':
menulog=key;
case 'D':
menulog=key;
case '0':
menulog=key;
menu='0';
key = kpd.getKey();
return menulog;
int numSensoresT = sensors.getDeviceCount();
float temparray[numSensoresT];
inicio:
if (menu=='0')
myGLCD.clrScr();
myGLCD.print("-MENU-", CENTER, 0);
myGLCD.drawLine(2,8,82,8);
myGLCD.print("#: Confirmar", CENTER, 10);
myGLCD.print("A: Config", 0, 20);
myGLCD.print("B: SD", 0, 30);
myGLCD.print("C: Datos", 0, 40);
myGLCD.update();
char menu=Defineletra();
else if (menu =='A')
myGLCD.clrScr();
myGLCD.print("CONFIGURACION", CENTER, 0);
myGLCD.print("A:Tiempo", 0, 10);
myGLCD.print("B: Sensores", 0, 20);
myGLCD.print("C: Unidades", 0, 30);
myGLCD.print("0: Volver", 0, 40);
myGLCD.update();
char menu1=Defineletra1();
if (menu1=='A')
{inicio3:
myGLCD.clrScr();
myGLCD.print("-TIEMPO-", CENTER, 0);
myGLCD.print("A:Fecha/h", 0, 10);
myGLCD.print("B: Periodo Log", 0, 20);
myGLCD.print("0: Volver", 0, 30);
myGLCD.update();
char menu3=Defineletra3();
if (menu3=='A')
while(fechahora=='0')
myGLCD.clrScr();
myGLCD.print("A:Correcto", 0, 0);
myGLCD.print("B:Cambiar", 0, 10);
verhora();
char fechahora=Definefechahora();
while(fechahora=='A')
{goto inicio3;}
while(fechahora=='B')
ponerhora();
{goto inicio3;}
else if (menu3=='B')
myGLCD.clrScr();
myGLCD.print("Definir unidad", 0, 0);
myGLCD.print("y pulsar #", CENTER, 10);
myGLCD.print("A: Horas", 0, 20);
myGLCD.print("B: Minutos", 0, 30);
myGLCD.print("C: Segundos", 0, 40);
myGLCD.update();
char unidad=Defineletra7();
myGLCD.clrScr();
myGLCD.print("Numero unidades", 0, 0);
myGLCD.print("#: Confirmar", 0, 10);
myGLCD.print(": Borrar", 0, 20);
myGLCD.update();
unsigned long num = Definenumero();
numero = num;
refresh_rate=(numt);
{goto inicio3;}
else if (menu3=='0')
{goto inicio;}
else if (menu1=='B')
{ inicio4:
myGLCD.clrScr();
myGLCD.print("SENSORES", 0, 0);
myGLCD.print("A:Temperatura", 0, 10);
myGLCD.print("B: Caudal", 0, 20);
myGLCD.update();
char menu4=Defineletra4();
