I'm trying to make this device work: Mixed-signal and digital signal processing ICs | Analog Devices
The wiring was easy, but I don't understand how to make the sketch work. It requires a library and I never used one before and it seems I'm doing something wrong. I would appreciate your kind help!
Sketch: http://wiki.thinkhole.org/ds1620
Library required: GitHub - jpmulligan/Arduino-DS1620: Arduino DS1620 library to interface an Arduino with the Dallas Semiconductor DS1620 Digital Thermometer and Thermostat
I quit Arduino
I unzipped the library into ~/Documents/Arduino/libraries/DS1620/ (it's a Mac, see attachment)
I put the example sketch into ~/Documents/Arduino/ds1620_example/ds1620_example.pde
I open the sketch with Arduino app and when I try to verify it gives me this error.
It highlighst this part in the code:
// Call DS1620 constructor using pin variables
DS1620 d = DS1620(dq, clk, rst);
And gives this error below:
ds1620_example.pde:50:20: error: DS1620.h: No such file or directory
ds1620_example:58: error: 'DS1620' does not name a type
ds1620_example.pde: In function 'void setup()':
ds1620_example:67: error: 'd' was not declared in this scope
ds1620_example.pde: In function 'void loop()':
ds1620_example:88: error: 'd' was not declared in this scope
