This is article 8 of 8 in a series about robust DS18B20 / 1-Wire system design.
Please see the introductory topic:
This is a short but very useful technique: a small trick that helps visualize the DS18B20 conversion time, which can take up to 750 ms at 12-bit resolution.
Many Arduino users are familiar with the classic heartbeat LED:
a small status blink that indicates the microcontroller is still running.
This is particularly helpful in systems that have:
no display
no serial monitor connected
no other visible output
A simple heartbeat reassures you that the firmware is alive.
The Classic Heartbeat LED
Typically the LED is toggled every few seconds.
Example (simplified):
pinMode(LED_BUILTIN, OUTPUT);
static unsigned long lastBlink = 0;
if (millis() - lastBlink >= 2000)
digitalWrite(LED_BUILTIN, HIGH);
delay(50);
digitalWrite(LED_BUILTIN, LOW);
lastBlink = millis();
This produces a short blink every two seconds.
It confirms that the main loop is still executing.
However, when working with a DS18B20 temperature sensor in blocking mode, the LED can provide even more useful information.
Using the DS18B20 Conversion Time as Optical Feedback
At 12-bit resolution, the DS18B20 conversion takes up to:
750 ms
During this time the processor is waiting for the sensor to complete the measurement.
Instead of letting this time pass silently, it can be used as a visual indicator.
The idea is simple:
turn the LED ON before starting the conversion
turn the LED OFF after reading the temperature
This means the LED stays on exactly during the conversion time.
Example sequence:
LED ON
requestTemperatures()
getTempCByIndex()
LED OFF
The LED therefore becomes a visual representation of sensor activity.
Why This Is Useful
This technique provides immediate visual feedback about sensor behavior.
Under normal conditions:
the LED stays on for roughly the conversion time
the blink pattern is stable and predictable
But if the sensor experiences problems, the LED pattern changes.
For example:
repeated reads
recovery attempts
additional conversion requests
All of these extend the LED ON time.
This makes it possible to see recovery behavior directly without using the serial monitor.
If an escalation strategy is implemented, the LED can visually reveal:
additional conversion attempts
retry loops
bus resets
longer recovery cycles
In other words:
The LED becomes a simple diagnostic instrument.
OFF-Time Behavior
The LED OFF period is determined by whatever else the loop is doing.
Typical contributors are:
other code inside the loop
communication routines
actuator control
or simply a
delay()used to slow down the loop.
This creates a natural timing pattern:
LED ON → sensor conversion
LED OFF → rest of the program
The result is a clear visual separation between measurement time and application logic.
Minimal Example
The following example demonstrates the concept with a DS18B20 running at 12-bit resolution in blocking mode.
It is intentionally kept minimal and fully compilable.
#include <OneWire.h>
#include <DallasTemperature.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
sensors.begin();
sensors.setResolution(12);
digitalWrite(LED_BUILTIN, HIGH); // LED ON: conversion starts
sensors.requestTemperatures(); // DS18B20 blocking conversion (up to ~750 ms at 12-bit)
float temp = sensors.getTempCByIndex(0);
// https://forum.arduino.cc/t/ds18b20-recovery-and-escalation-strategy/1433190
digitalWrite(LED_BUILTIN, LOW); // LED OFF: conversion finished
Serial.print("Temperature: ");
Serial.println(temp);
delay(1000); // slow down loop
What You Will Observe
With this setup:
the LED stays ON for ~750 ms
the LED stays OFF during the rest of the loop
If the sensor behaves normally, the blink pattern remains stable.
If problems occur (slow responses, retries, recovery attempts), the ON time becomes longer.
This provides a surprisingly effective visual debugging tool.
A Small Trick with Big Value
This technique costs:
one LED
two lines of code
Yet it can reveal a lot about the timing behavior of a DS18B20 system.
Especially during development, it offers an immediate visual indication of:
sensor timing
loop timing
recovery behavior
abnormal delays
This simple LED technique can help understand DS18B20 timing behavior and detect unusual conversion delays during debugging. => Sometimes the simplest diagnostics are the most effective ones.
