I fund an old topic about the ds18b20 reading -127 (now closed!) but i wanted to add that the problem was not addressed properly hence no solution was found to that topic:
solution : I experimented with the Dallas temperature sensor and to get the sensor to read (and display) the correct temperature need to connect a 4.7k resistor between the + and data pin of the sensor. (no library problems were found! )
The pull-up is a necessary part of the connection because of open-drain nature of the transceiver section of the DS18B20 sensor.
Hi.
I don't know what this topic says you quoted, but
DS18B20 can also work in " PARASITE POWER" mode, using only 2 wires. GND and DQ.
See at:
topic : PARASITE POWER.
It can't be too difficult to address, and the solution is well-known:
-127 means no, or improper, connection.
Check your wiring.
End of story.
However, per figure 6 on p.7, a hard pullup and MOSFET are required for proper operation.
I believe THIS is the topic sparkone is referring to. A hard pullup was suggested but no followup from the OP. Don't you hate it when that happens?
Correct
No great surprise. It often happens when the bleeding obvious is posted by somebody who knows what they are doing - resulting in embarassing silence. All Photoncatcher did was wire up the sensor the way God and Dallas intended. No mention of MOSFET and no parasite power either.
the old topic ! had blamed the library but it was not the case ; connecting as pictured showed correct readings rather than -127....sometimes wrong connections by mistake bring up errors hence pictured for reference. ( & quite often than not its not always about dificulty of atask rather getting the basics right! ) Hope it helps someone! ta
Your graphic shows wrong polarity, if looking at the TO92 package flat side with leads at bottom, Vcc (+) is on right, GND (-) is on left.
The posted connection of DS18B20 seems to be wrong when compared with the following taken from data sheets:
Then please, repost your above diagram showing pin numbers and inscribing DS18B20 on the flat side of the chip.
thanks
